Estimating Wave Size?
Old 04-30-2007 | 12:31 AM
Default Estimating Wave Size?
I see people quoting the size of waves that they were running in. How does one go about estimating the size of the wave? It seems very arbitrary, are there good rules of thumbs to go by?
wrasse is offline
Old 04-30-2007 | 01:03 AM
In oceanography, wave height (fig. l-31) is the vertical distance, usually measured in feet, from the crest of a wave (the highest portion of a wave) to the trough of the wave (the lowest portion of the wave). This differs from the "wave height" or "amplitude" normally used in physics, in which the distance is measured from the "at rest" or midline position to the crests and troughs.
http://www.tpub.com/content/aerograp...s/14269_58.htm
jackhammer is offline
Old 04-30-2007 | 08:48 AM
NefariousOne's Avatar
It seems to me that the average boater over estimates actual wave height most of the time. I work off shore, and and most of the "marine crew" I work with (ie captains and first officers) usually call wave height pretty damn good.
You hear guys saying they run x mph in 4-6's or 6-8's...... OK sure.... True 6-8's are no joke.
I'm guilty of the wave over estimation as well, don't get me wrong...
NefariousOne is offline
Old 04-30-2007 | 09:07 AM
I always listen to the marine forecast and check a few bouys on the NOAA website before I go out. So I figure if NOAA says it 2-4 ft ...its 2-4 ft.
Dangerous Dave is offline
Old 04-30-2007 | 09:09 AM
GLH's Avatar
GLH
Originally Posted by NefariousOne
It seems to me that the average boater over estimates actual wave height most of the time....
Major culprit...
GLH is offline
Old 04-30-2007 | 09:23 AM
Originally Posted by GLH
Major culprit...
I thought if their keychain said APACHE or CIGARETTE that was the major culprit!
Jupiter Sunsation is offline
Old 04-30-2007 | 09:26 AM
sakoutis3's Avatar
Big mouth x ego + % boat brand = wave hieght if alcohole is included in said formula add 2 feet
sakoutis3 is offline
Old 04-30-2007 | 09:34 AM
Stormrider's Avatar
JC Performance Engines
To some a swell is a wave.
But to me, they are not the same.
And yes, you can run 60-80mph in 8ft swells.
But 8ft waves would be punishing, depending on the frequency.
Stormrider is offline
Old 04-30-2007 | 09:37 AM
simple .stop the boat, stand up,,when your in the troughand look out ..if it looks eyelevel, its 4~5' if it looks as high as your head or just over its 5~6' if it looks twice as high as you 8~9' if you just sh*t yourself and said were screwed then hollered mayday on the radio, your rolling in 10 footers..if you look up and see a 2 story house, have resolved yourself to the fact your going to die, locked yourself in the cabin with an appeltons and coke and a cuban cigar, waiting for Davey Jones to knock on the door and joing the party, its prolly over 12
phragle is offline
Old 04-30-2007 | 09:52 AM
GLH's Avatar
GLH
I'm sure if all you have is the keychain it can't help.
What do those run now $7 or $8 bucks?
GLH is offline
