Another fuel question- EFI fuel filter?  Can I use my stock merc filter or not? >
Old 04-30-2007 | 09:59 AM
zimm17's Avatar
Default Another fuel question- EFI fuel filter? Can I use my stock merc filter or not?
Okay, so the other thread has me convinced to run a new 1/2" line from the tank to the engine compartment. I'm going to mount my SX fuel pump to the stringer, AN-10 fittings on that to the regulator.
Now what about the fuel filter? I have the stock 1996 merc fuel filter/water seperator for a carberator. I don't even know if that the thing can handle 50psi. It has two inlets and outlets so I could split my AN-10 line into both 3/8" ports... or just get rid of the thing and use an inline filter. Maybe water isn't a bad thing with a EFI system- no fuel bowls for water to accumulate. What filter should I run, and where in the system does it go?
zimm17 is offline
Old 05-01-2007 | 09:44 AM
That's a good question. Anybody? If you keep it drill out the ports and re-thread for larger fittings. I was wondering about deleting mine to get rid of the restriction.
kennyo is offline
Old 05-01-2007 | 01:00 PM
Airpacker's Avatar
The filter/seperator needs to be on the suction side of the pump. It is not intended to see high pressure. If the regulator fails, pressure could exceed 90 psi. Any way you slice it, water is BAD!
Airpacker is offline
Old 05-01-2007 | 01:58 PM
zimm17's Avatar
OK, so plumb in the stock filter, or go aftermarket? 600HP whipple EFI'd 454...
zimm17 is offline
Ken N
14
12-03-2007 06:29 PM
J.B. Marshall
0
08-27-2007 03:55 PM
gsmith9898
3
06-26-2006 07:42 PM
swilson1973
04-10-2006 09:01 AM
Cattitude
2
08-11-2004 12:41 PM
