05 F250 Diesel 31K miles????
Old 04-30-2007 | 01:12 PM
tomtbone1993's Avatar
Default 05 F250 Diesel 31K miles????
Any issues? what should I be concerned with?
tomtbone1993 is offline
Old 04-30-2007 | 01:46 PM
Jassman's Avatar
None, I had 2 both great trucks, replaced the with 2 more F-250's and now 1 07 F-350 dually. Springs in front I believe this year, slightly smoother and better turnng radius. Good Luck Jeff
Jassman is offline
Old 04-30-2007 | 01:51 PM
CigDaze's Avatar
None. I have an '05 F-250 CC PSD FX4 with 34K, and have not had one issue.
CigDaze is offline
Old 04-30-2007 | 01:53 PM
good deal it has been hard for me to let go of my 00 7.3, But I really need the room of a crew cab
Old 04-30-2007 | 02:18 PM
ZBODaytona's Avatar
I have an 05 CC dual wheel 4x4 with 6.0 with the same miliage...so far so good...knock on wood...
ZBODaytona is offline
Old 04-30-2007 | 02:35 PM
I have an '05 F250 CC 4x4 with 41k miles. No problems to date. Does a great job towing.
ciaoderhead is offline
Old 04-30-2007 | 03:58 PM
Jakester's Avatar
Boomer! Sooner!
Make sure the fuel filters were changed every 10k. If they were not the injectors have probaly been damaged. The 6.0 lives or dies off of fuel pressure.
I would also run the VIN# through an Oasis report from Ford. THis will tell you all of the warranty work that has been performed on the truck. If it has a bad history i would pass.
Jakester is offline
Old 04-30-2007 | 06:33 PM
I have 95k on my 05 and 15k on my 07 no problems so far .
1bagger is offline
Old 04-30-2007 | 06:47 PM
here is a pic...anybody want to buy the camper?
Attached Thumbnails 05 F250 Diesel 31K miles????-2005-f-250-001.jpg   05 F250 Diesel 31K miles????-2005-f-250-007.jpg
Old 04-30-2007 | 06:56 PM
Wobble's Avatar
SORE MEMBER
You would be buying a Ford off of a GMC lot, what else do you need to know
Wobble is offline
