Water (circ) pump failure >
Old 05-05-2007 | 11:38 PM
Default Water (circ) pump failure
Anyone ever see or have an impeller fall of a circulation pump? (the one on the engine, almost similar to a car/truck)
Mine did, found by pure chance by spinning the pulley with the belts off and it made a funny noise. Pump was mercruiser and only one season on it. Looked like wasn't brazed on.
I am very tempted to put an automotive one on it, even though I have a new one at $135.
jmherbert is offline
Old 05-06-2007 | 09:31 AM
I just put a new circ pump on Friday night. Had just finished replacing thermostats and the thing started howling. The pulley was loose because the shaft has broken in some way. Once I got the pulley off I could see it had been dying a slow death-the weep holes had corroded nearly shut.
handfulz28 is offline
Old 05-06-2007 | 09:37 AM
Marine ones have stainless impeller , automotive are plain steel. Even if you run in fresh water I would spend the $100 on a marine one, they rarely fail, sounds like you had a goofy defect.
happy hours is offline
Old 05-06-2007 | 03:04 PM
The impellers are actually bronze or cast brass. The old bad one was a OEM merc, and so is the new one. I have both a new Merc and an automotive type on hand.
Old 05-06-2007 | 04:41 PM
Pwrbt33's Avatar
Just keep in mind that if you still have the reciept that Mercury gives a year on those pumps.
john
Pwrbt33 is offline
Old 05-07-2007 | 12:59 PM
ENFORCER24's Avatar
i just replaced mine , never made a noise but rust made a lil hole in the top and it was pee'ing all over my engine
ebasicpower sold me mine brand new aftermarket for 65 after shipping , hella deal for a marine 454 circulating pump
ENFORCER24 is offline
scarabfun
3
05-15-2008 09:10 PM
scarabfun
14
02-25-2008 06:09 PM
nocigarette
9
05-16-2006 04:24 PM
RMM
2
05-10-2005 08:35 PM
challenger454
12
07-13-2004 03:06 PM
