Leaking Silent Choice >
Old 05-06-2007 | 01:01 PM
mats's Avatar
Default Leaking Silent Choice
One of the Silent Choice diverters leaks where the shaft comes out of the diverter. Anyone experienced this and knows what to do about it? It is leaking on the actuator side.
mats is offline
Old 05-06-2007 | 02:48 PM
is it Merc air silent choice??
If it is I had that, that was one of a bunch of probs I had......eventually replaced it with Corsa electric......MUCH happier.
pullmytrigger is offline
Old 05-06-2007 | 04:21 PM
mats's Avatar
Yes, it is merc......
mats is offline
Old 05-06-2007 | 04:37 PM
Pwrbt33's Avatar
The only thing I have ever done with Mercury Silent Choice is pull them out, disassemble it, polish the shaft and install a new seal. Make sure you use a little dab of blue locktite on the flapper bolts.
John
Pwrbt33 is offline
Old 05-07-2007 | 12:51 AM
mats's Avatar
Is the seal a " standard component" that can be bought somewhere?
mats is offline
Old 05-07-2007 | 10:47 AM
UNSANE's Avatar
I had that happen with mine. I called CMI and got a rebuild kit with new seals for pretty cheap. (I have a 525 with the CMI exhaust) Just call Merc.
UNSANE is offline
Old 05-07-2007 | 12:05 PM
How long b-4 these things begin to leak??? I just installed a set of Corsa's.
ghittner is offline
Old 05-08-2007 | 11:52 AM
mats's Avatar
I dont know about the Corsas, but it took 6 years and 600 hours for my mercs to start leaking. I have ordered the rebuild kit now. Thanks for the help.
mats is offline
Old 05-08-2007 | 11:57 AM
razor1115's Avatar
mats,
Do you have a part number? I have one doing the same thing. Also, is it just a standard lip seal I can pick up somewhere?
razor1115 is offline
Old 05-08-2007 | 12:12 PM
mats's Avatar
I called the spare parts department at Mercury, so I dont know the part numbers. But for each diverter there was two types of seals for each side of the diverter in all four seals per diverter
mats is offline
