Painting B1 Lower Units
Old 05-07-2007 | 03:33 AM
cig1988's Avatar
Default Painting B1 Lower Units
In the process of re finishing my nose cones. I'm pondering the thought of a change from a simple black to a aluminum color just on the lower untis. Any pics, thoughts, color codes ?
cig1988 is offline
Old 05-07-2007 | 09:34 PM
monstaaa's Avatar
if you installed nose cones, make sure you use a good epoxy primer . and dont forget to coat the inside of the old water cavity with the primer, so you dont get water penitration from the inside out.
as for a silver , mercedes benz brilliant silber metalique is an awesome color.
monstaaa is offline
Old 05-08-2007 | 03:02 AM
cig1988's Avatar
The cones were already installed ages ago & keep cracking. I removed everything that was there & found they were welded on some what. Sandblasted all the surrounding areas filling in the valley with Norton Speed Grip (poly urethane adhesive). Should be up to the USC "All Metal" by today as a filler. Definetly using the epoxy primer (PPG DP90LF). Hopefully this will be the last time I need to do this. I'll look up that Benz color-Thanks.
cig1988 is offline
Old 05-08-2007 | 08:22 AM
ziemer's Avatar
I've mentioned this before, but I like to finish mine with a sandable black primer from the top of the bullet down. That way when your skeg finds the bottom in shallow areas (which it will ), it's an easy touch up to fix.
ziemer is offline
Old 05-08-2007 | 08:49 AM
tssteph's Avatar
I just did mine the same way. I went with some silver I had left over. I resprayed the upper units black as well after fixing all the nicks and chips.
Attached Thumbnails Painting B1 Lower Units-pic00001.jpg   Painting B1 Lower Units-pic00002.jpg
tssteph is offline
Old 05-08-2007 | 11:40 AM
monstaaa's Avatar
when you paint them use a good etcher to help with adhesion. hopefully you ve used duraglass or an equivalent to make your repairs
goodluxk.
monstaaa is offline
Old 05-08-2007 | 07:29 PM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
when I did my drives I prepped with alumiprep and alodyne
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 05-09-2007 | 03:23 AM
cig1988's Avatar
Looks really sharp. I like the way the color separates at the bottom and not to the top side. (Imco) Good work !
cig1988 is offline
Old 05-09-2007 | 03:35 AM
cig1988's Avatar
Monstaaa
Instead of the duraglass I'm using the USC All Metal. This should work unless anyone has had bad results. Will be using a 2 part finishing glaze once rough work is completed.
Klaw
How the heck ya doing ?
I've never used what you suggested but may be well worth it. Available in Auto Body Supply stores ?
cig1988 is offline
Old 05-09-2007 | 08:20 AM
klaw's Avatar
when I painted my drive and did all of the research for painting aluminum alumiprep came up as the surface prepping solution and alodyne was a pretreatment for better adheasion. yes anybody who crries ppg or prob any other paint should carry it.
klaw is offline
