Electric trailer brake in new Ford SD >
Old 05-07-2007 | 04:10 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
Default Electric trailer brake in new Ford SD
Has anyone had any experience with the factory installed electric trailer brake in the 08 SD? Does it work well with the electric over hydrolic trailer brakes?
Thanks!
mcraymond3 is offline
Old 05-07-2007 | 04:23 PM
44MTI's Avatar
Doesn't work with Electic over Hydrolic, only all electric. If you hit the brakes pretty hard you will notice a little braking from the trailer. I was a little let down when we first found out.
44MTI is offline
Old 05-07-2007 | 06:49 PM
J.B. Marshall's Avatar
JB Marshall
It will work with electric over hydraulic, you need to install a brake module from carlisle. It is called a HBA-Cam controller will cost around $100.
I installed one on my manning trailer and it works like a dream and the factory brake controller is sweet.
J.B. Marshall is offline
Old 05-07-2007 | 07:13 PM
Panic Button's Avatar
Emerald Coast of Florida
Depends on the model of E/H actuator. BrakeRite tested theirs on the 05-07 & 08 models without any issues, per their tech support people.
Panic Button is offline
Old 05-09-2007 | 05:18 AM
Works well with my Ausco on my Extreme Trailer.
SkiDoc is offline
Old 05-22-2007 | 09:34 AM
44MTI's Avatar
Where did you purchase it from. It sounds like you add this to your trailer, is that correct.
44MTI is offline
Old 05-22-2007 | 10:42 AM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
http://www.carlislebrake.com/product...roller_fix.php
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 05-22-2007 | 04:41 PM
JB Marshall
Yes I did add it to the trailer to make it work with the Ford controller. Follow the link above.
Old 05-22-2007 | 08:50 PM
44MTI's Avatar
Thanks guys, I ordered one today off their website. This should make life much better.
44MTI is offline
Old 05-22-2007 | 08:54 PM
Default 382 w brake rite
Works great with Tow Command. You will be really pleased with the way the trailer is controlled. As good as air brakes !! Mine will slide all the tires with the boat on the trailer if it is set too high !! Thats stopping power
382 newbie is offline
