Prop Slip - Labbed vs. Stock >
Old 05-08-2007 | 01:22 PM
StillHaulin@63's Avatar
Default Prop Slip - Labbed vs. Stock
I was told by my marine mechanic that, with the same pitch prop, a labbed version will provide less
mid-range cruising efficiency than that a stock version of the same prop. I also had noticed the difference when testing both a labbed 24p B/1 4-blade as well as a stock one on my 23' hull.
I assume this is caused by slippage due to the thinner blades.
Is this true?
StillHaulin@63 is offline
Old 05-08-2007 | 02:54 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
The recipe used when Labbing determines the end result.
A "standard" Lab recipe developed 15 years ago at Merc Racing for a Bravo 1 will allow for a 1-2 mph cruise loss on a sport boat. It may gain 4-5 on the top though.
Hull design , power, and Lab recipe determine the outcome.
Remember, Labbing was designed for speed. There are other advantages to Labbing also.
[email protected]
bbladesprops is offline
Old 05-08-2007 | 03:09 PM
Thanks for the input ...
Other than WOT top speed, what are the other advantages?
Also, is it fair to assume that thinner blades allow more prop slip?
Old 05-08-2007 | 04:32 PM
Smile
Thin blades do not induce slip.
Advantages often overlooked that I really like to tell folks about is Acceleration and buttery smooth operation.
Brett
[email protected]
Old 05-08-2007 | 05:59 PM
What makes the "labbing" cause a loss in cruising efficiency?
Wouldn't you have the same amount of pitch and blade surface?
Old 05-08-2007 | 06:19 PM
gsmith9898's Avatar
I just changed to a 2 inch shortie and my slip number went from 8% to 13% with the same prop. Why is that?
gsmith9898 is offline
Old 05-08-2007 | 06:38 PM
crb76's Avatar
Drive height
crb76 is offline
Old 05-08-2007 | 07:26 PM
gsmith9898's Avatar
Any way to get the slip numbers down?
Old 05-08-2007 | 07:30 PM
throttleup's Avatar
The acutal pitch of a lab finished prop, in most cases, is lower than that of a non-lab finished prop. Your slip really does not go up with a lab finished prop compared to a stock prop when you take into account the true pitch of the lab finished prop.
throttleup is offline
Old 05-08-2007 | 08:24 PM
sounds like your X demension is to high. I would try a 1" spacer. What kind of drive?
B BOATER is offline
