Baseline jetting >
Baseline jetting
Baseline jetting
Old 05-10-2007 | 07:10 PM
Default Baseline jetting
I'm in the process of piecing my 454 back together that I found water in this spring. It started as a stock 330 but will now have a set of factory rect. port heads, dual plane intake, and a 750 DP. The valvetrain and comp. ratio will be unchanged. I know this isn't a great combo, but the budget for engine upgrades this year was zero (until the water problem). I'm needing advise on carb jetting. Right now the 750 has the original 73/81's in it. I just need to get it close until I get on the water and start tuning. Thanks.
tjsmk8 is offline
Old 05-10-2007 | 07:22 PM
I would say your at a good starting point . You might be a little lean in the primarys. Check plug readings at the RPM just before the secondarys open .
sschafee01@snet.net is offline
ratman
Prop Talk
3
11-11-2005 10:23 AM
Bill Watson
Fountain
2
08-06-2004 03:54 PM
jryan26
5
05-14-2004 05:36 PM
Excalibur
5
04-30-2004 03:07 PM
PROFILE
1
02-06-2003 02:50 PM
