It Felt Good >
It Felt Good
It Felt Good
Old 05-12-2007 | 11:37 PM
jersey's Avatar
It Felt Good
Finally got out today on the barnegate bay 03' 29 OUTLAW 496 mags got up to 71.2 gps
jersey is offline
Old 05-13-2007 | 12:03 AM
AIR TIME's Avatar
congrats
AIR TIME is offline
Old 05-13-2007 | 04:33 PM
JasonSmith's Avatar
Good job! Ain't the 29 a sweet ride!
JasonSmith is offline
Old 05-14-2007 | 01:28 PM
jersey's Avatar
luv it except for the chine walk
jersey is offline
Old 05-14-2007 | 09:03 PM
JasonSmith's Avatar
Shouldn't see any chine walk on a 29. Mine doesn't do it & I'm running 86 GPS MPH right now & expect about 7-8 more out of it when I get it dialed in.
Old 05-15-2007 | 11:04 AM
jersey's Avatar
I get it when there is alittle chop from the side , I think the drives are set to low.
jersey is offline
Old 05-15-2007 | 11:17 AM
JasonSmith's Avatar
Your boat has a raised x-dimension from Baja. They started playing with the x in the early 2000 models. So your drives are not too deep. If they were deep you wouldn't have the speed nor would you have what you think you have in chine walk. A 29 won't chine walk with factory power. They just aren't fast enough. They don't ride far enough out of the water either. You are just being effected by the condition of the water you are running in. You can compensate for this by setting the trim tabs at neutral & tucking the drives a little.
Are you running 3 or 4 blade propellers? Are your propellers spinning in or out?
I'm here to help!
Old 05-17-2007 | 02:48 PM
jersey's Avatar
Four blade 26 bravo I'm not sure which way they are spinning I think out.
jersey is offline
Old 05-17-2007 | 10:52 PM
JasonSmith's Avatar
Spinning out is the most stable way. Takes less trim also to get the nose up.
Old 05-20-2007 | 10:46 PM
fatdaddy's Avatar
Sounds good. I hope to see ya out there. I have a 33 w/ custom paint and run out of Bayville.
fatdaddy is offline
