How do I advance cam with 3 way cloyes timing chain, SBC >
Old 05-14-2007 | 06:26 PM
Full Force's Avatar
Default How do I advance cam with 3 way cloyes timing chain, SBC
I need to advance my cam 4 degrees, I have a cloyes 3 way timing chain, I know the dot is straight up, what is the rectangle? what is the triangle, I know they are 4 degrees but I don't know which one I need for advancing it, I cannot find the paperwork...
Thanks, Tim
Full Force is offline
Old 05-14-2007 | 10:44 PM
I'd give Cloyes a shout, they should be able to help you out.
SneakyPete is offline
Old 05-15-2007 | 05:08 AM
Full Force's Avatar
Ok, thanks.
Old 05-15-2007 | 09:38 PM
If you can't find the info, I have a paper at work with the info. Just did one the other day. I bring it home tomorrow.
Noise Pollution is offline
Old 05-15-2007 | 09:40 PM
Full Force's Avatar
I called Summit, they helped me, thanks guys..
Old 05-16-2007 | 07:49 PM
Make sure to check piston to valve clearance if you are going to advance the cam, especially if it is much larger than stock.
BillK is offline
Old 05-16-2007 | 08:07 PM
Linster's Avatar
Off the Radar
Originally Posted by BillK
245,
Great advice,
If you need to advance that much, the cam is way off. Boats dont work like cars because they do not coast.
Linster is offline
Old 05-16-2007 | 08:16 PM
Full Force's Avatar
Originally Posted by Linster
Great advice,
Actually Cam Motion is well known for the advice they give, i have used them for years, always very happy with the results, he said the cam I have is a good cam but just needed the power band brought down, he would recommend a little different if I was buying one but since I was using what I had he said to advance it.
Alot of the crate engines I have looked at are running almost the same cam I have with power gains I am looking for.
Old 05-16-2007 | 08:17 PM
Full Force's Avatar
245,
I always check, especially after moving a cam around, thanks, Tim
Old 05-16-2007 | 08:26 PM
Linster's Avatar
Off the Radar
Im hope the advance works, let us know how it did.
Linster is offline
