Prop talk gurus's ??
Pirate of the Chesapeake
I have a 202 chris stinger and will be swapping to ruffly 350 hp with in the next few weeks. I am going to be using the 6 cyl drive on it till i get money to upgrade, I believe the ratio is 1.73.What size- pitch prop would you reco for this set up. Stock alpha drive redline in the neighborhood of 5500, it can't weigh more then 2200 lbs.. Would I benift from a clever over a bravo, or other.. It likes to run out of trim fast, a clever likes the surface better then the others correct??
Thanks for any help gents...
John
John
