New Livorsi gauges any feedback? >
Old 05-14-2007 | 10:25 PM
LubeJobs42's Avatar
Default New Livorsi gauges any feedback?
Anyone use the new Livorsi gauges that have
Tachs, gps speedo, compass heading, prop slip. They look very cool. Wonder how accurate they are and if they work with big power.
Attached Thumbnails New Livorsi gauges any feedback?-datatach%2520blk%2520points_lg.gif
LubeJobs42 is offline
Old 05-15-2007 | 06:49 AM
contact mark wharton @ prop slip,he can answer all ?'s.i had a chance to work w/ him @ the miami show,this gauge is the real deal.
propslip.com
402-218-6209
dollerparts is offline
Old 05-15-2007 | 11:44 AM
Yes sir, they look and work awesome...you have to program the unit with specific information about the boat so they work with any boat and power configuration.
You can check out this link for a bit more information or give me a call if I can answer any questions for you.
http://www.tpmarine.com/index.asp?Pa...odID=1468&HS=1
Thanks,
Don B.
505 345-3760
tpmarine.com is offline
Old 05-15-2007 | 03:06 PM
jhiguy377's Avatar
1.6 mph, is that as good as it gets?
jeff
jhiguy377 is offline
Old 05-15-2007 | 08:50 PM
Adjust your glasses, it reads 101.6 MPH!
509 SC is offline
Old 05-15-2007 | 10:04 PM
looks good to me i'll have to give todd a call and get some comin
lightning jet is offline
Old 05-16-2007 | 08:01 AM
zitoracing's Avatar
gcoffshore.com
Is the gauge the same size as the speedo hole in the dash look to be the same.
zitoracing is offline
Old 05-16-2007 | 09:00 AM
The cut-out size is 4 5/8" so if you are currently running a monster speedo it will fit in your existing cut-out.
Keep in mind that you will not longer need to run a seperate tach. since it is built into the datatach/prop slip multi gauge.
I am working with all my customer to help them redesign and replace their dash panels where necessary. You could always leave the analog tach in place and run it along with the digital tach.
Old 05-16-2007 | 09:12 AM
Outdrive1's Avatar
Masher touches my
Another dash....................
Damn that looks nice.
Outdrive1 is offline
Old 05-16-2007 | 12:18 PM
Let me know when you would like to add it to the Kachina...
