removing decals from fiberglass >
Old 05-15-2007 | 05:59 PM
rtaylor's Avatar
Default removing decals from fiberglass
Just bought a used boat that has 2 little decals on it that need to be removed. Are there any techniques you can share?
Thanks.
rtaylor is offline
Old 05-15-2007 | 06:02 PM
blow dryer.... heat it up... and peel away
dreamer is offline
Old 05-15-2007 | 06:03 PM
lucky strike's Avatar
Hair dryer or a heat gun.
lucky strike is offline
Old 05-15-2007 | 06:04 PM
Your quick bro !
Old 05-15-2007 | 06:31 PM
Originally Posted by lucky strike
Your quick bro !
might be down monday...
dreamer is offline
Old 05-15-2007 | 09:26 PM
Stop by the showroom if you get a chance.
Old 05-16-2007 | 12:40 AM
Playn's Avatar
I was going topost a similar question. I did the heat gun thing and got the decals off but it left a residue. GooGone doesn't work in removing the residue....any suggestions?
Playn is offline
Old 05-16-2007 | 12:44 AM
acetone and then wash and wax
Griff is offline
Old 05-16-2007 | 03:30 AM
cig1988's Avatar
3M makes an eraser you put on a drill. Forgot the technical name of it. That is what you need.
cig1988 is offline
Old 05-16-2007 | 06:06 AM
offshoredrillin's Avatar
3M makes an adhesive remover, comes in a red spray can, Napa or any auto parts store carries it, bout 8 bucks, wont hurt gel, then wax as it will strip any off.
offshoredrillin is offline
