do i need 2 amps?
Old 05-17-2007 | 07:48 AM
Default do i need 2 amps?
Ive got a set of 10" subs that run 130w RMS, and a set of 6.5" speakers that run 65w RMS. Can i get one amp to power all 4 speakers, a 4 channel maybe that will not blow the 6.5's but will not under power the 10's?
Boomer35 is offline
Old 05-17-2007 | 08:21 AM
Wally's Avatar
Were doomed!
if you got a good 4 chan amp that can run 2ohm stable you can run the 6.5's on the first two chan and bridge the other two and run the 10's in parallel at 2 ohms and you would be ok with plenty of power
-Wally
Wally is offline
Old 05-17-2007 | 10:31 AM
UNSANE's Avatar
2 amps, each matched to their repsective speaker load.
UNSANE is offline
Old 05-17-2007 | 10:54 AM
88formula223's Avatar
NO WAKE ENFORCER
It would sound much better if you added a second set of 6.5's and use a 4 channel amp such as these
http://www.onlinecarstereo.com/CarAu...x?CategoryID=3
And a mono amp in paralel as mentioned above
http://www.onlinecarstereo.com/CarAu...x?CategoryID=1
these are what I would buy, Pioneer cheap and good enough for a boat and will last and sound decent for the system you are putting together
sub amp
http://www.onlinecarstereo.com/CarAu...roductID=16659
mids / highs amp
http://www.onlinecarstereo.com/CarAu...roductID=16660
88formula223 is offline
Old 05-17-2007 | 01:02 PM
ive got a second set of 6.5's, i was going to run them off the deck, the deck is the clarion water proof, CMD5 (something like that)
Boomer35 is offline
Old 05-17-2007 | 02:39 PM
NO WAKE ENFORCER
cleaner power through the amp and for the low cost of those amps it will be well worth it, what kind of 6.5's and subs do you have? where are you putting the subs
US1 Fountain
Fountain
10
01-28-2007 10:34 PM
boatman747
9
11-13-2005 08:18 PM
BenPerfected
1
08-25-2005 10:07 PM
klaw
11-30-2004 06:55 PM
liquid asset
12-08-2002 11:04 AM
