cleaver or rounded blades? >
Old 05-18-2007 | 09:35 AM
paul m sahady's Avatar
Default cleaver or rounded blades?
i'm running a hydromotive 24p quad cleaver race labbed with a slight cup back at the tips. the motor is a 500 efi normally aspirated but built to crank 560hp(dyno at shaft). braov xr 1:1.5 ratio. the boat is a scarab 26 weighing in at 4800 lb. i get 5250-5300 rpm for a solid 73mph on gps (40 gal of fuel and 4 people). i am very pleased with the attitude and control of the present set up. mid range power is excellent. the out of the hole is a bit touchy, too much throttle and all you get is spin. the question is: if i switch to a round blade of the same pitch, lab and cup, will it hook up better out of the hole and will i get any more top end or am i just sacrificing the stern lift? any thoughts would be helpful.
paul m sahady is offline
Old 05-18-2007 | 10:50 AM
Pat McPherson's Avatar
I'd try a stock 26p Bravo one and see how she runs. "Labbing" the stock prop can get you a little more on top and change the attitude if necessary.
I would think that your straight V would run well with less stern lift.
Patrick
Pat McPherson is offline
Old 05-19-2007 | 06:46 AM
monstaaa's Avatar
round ear, maybe some cup.
monstaaa is offline
Old 05-19-2007 | 09:17 PM
Rebel_Heart's Avatar
I just tried a Bravo on my 35' Fountain after running Hydros. Much better handling characteristics. I will be labbing shortly to gain speed.
Rebel_Heart is offline
Old 05-20-2007 | 05:25 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Agreed, try a Bravo 1 propeller.
[email protected]
bbladesprops is offline
Old 05-21-2007 | 10:16 AM
i spoke with julie at throttle up today and she made alot of sense. i just wanted to thank her for the consult and the straight advice.
mv35
Prop Talk
14
01-06-2009 07:59 PM
Adrenaline Junkie
Prop Talk
3
07-24-2008 08:44 PM
JS232
Prop Talk
14
04-25-2006 10:19 PM
tewks
25
03-21-2005 12:16 PM
