tv install 25 ol. >
tv install 25 ol.
tv install 25 ol.
Old 05-18-2007 | 12:15 PM
yesrej's Avatar
Default tv install 25 ol.
ok im trying to install a tv in my cabin of a 25ol. where do i start? where do i put it? i was thinking of putting it on the port side wall behind the glove box. what do i need? whats the best way of doing this? i have the tv and the wall mount but now what. thanks for the help.
yesrej is offline
Old 05-18-2007 | 12:17 PM
yesrej's Avatar
oh i wll also have satilite tv when at the dock and i will what to be able to take the tv off while running.
yesrej is offline
Old 05-18-2007 | 12:33 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Not a Baja, so can'thelp you on the placement, but I made a tight fitting box to mount my flatscreeen TV that secures the outside of mine, plus the back mounting holes to, then mounted the box to my cabinet wall. The back alone of the TV didn't look sturdy enough to take the beating a boat dishes out. Wrapped in vinyl to finish it off. The box frame is wedge shaped to angle the TV to the other side of the cabin.
US1 Fountain is offline
Old 05-18-2007 | 12:46 PM
yesrej's Avatar
thanks. i was reading your thread when you did it. it looks great. im trying to figure if i get an inverter what would be the best way to ru the wires plus i have to run the cable wire to the dock. im trying to makes this look good but still be able to remove when running.
yesrej is offline
Old 05-18-2007 | 06:39 PM
jonyb's Avatar
Just mount it to the wall. You can remove the speaker on that side to get access to run the power wire and RG6 for satellite to the gunnels, then back to the engine bay to the battery. If you're buying a home tv, you'll need to install a power inverter to power it up.
jonyb is offline
Old 05-20-2007 | 07:56 PM
Ginger or Mary Ann?
There are several Flat screens that are advertised as 120VAC, but really are just DC TV's that have the AC to DC convertor in the power cord, like your laptop PC. Some are 16VDC, some 12VDC. Look on the rear of the TV's where they plug in if the cord has the convertor box in it to see what the DC power input is. Mine is a Sharp Aquos that happens to be 12VDC input. I picked up a plug from Radio Shack that plugs into the TV and wired it directly from my cabin's 12V fused power panel. Or could just cut the plug off and use it. I wanted to keep my cord uncut. I don't have to hassle with an invertor. I have shorepower and onboard battery charger, so draining a battery is not an issue while at the dock, but it would take
several hrs anyways to drain a battery down with just the TV while out on the water.
NEVERSATISFIED
15
09-07-2008 11:48 PM
BraceYourself
Cigarette
8
02-09-2007 12:49 PM
CAP071
01-24-2006 03:12 PM
orjan
0
07-26-2005 02:32 AM
HiPerf2000
Sonic
8
07-01-2005 08:34 AM
