Cold air intake on f250 SD. >
Old 05-19-2007 | 02:53 PM
Default Cold air intake on f250 SD.
Anyone put one on there truck yet with a 6.0. Did it do anything?
Velocity Tom is offline
Old 05-19-2007 | 03:17 PM
Jassman's Avatar
Go to the truck forum...
Jassman is offline
Old 05-19-2007 | 04:30 PM
DRIVEN1's Avatar
I will let you know in a week. I just ordered the Banks Ram-Air intake and turbo bank exhaust last week. It is going to go with the Six-Gun that I have waiting for it. Mike
DRIVEN1 is offline
Old 05-19-2007 | 04:38 PM
Im realy not looking for hp. but more mpg. I have a ford dealer for a customer, And thay have the 6.0s lined up for head gaskets. And its not cover under war. If it has been changed.
Old 05-19-2007 | 05:26 PM
The only intake proven to flow more than the stock unit is the afe stage 3. It retails around $500 and only flows about 50-60cfm more. Save your money.
Jakkle5 is offline
Old 05-19-2007 | 06:13 PM
Dean Ferry's Avatar
Tom,
Same concern here with my 2006, I don't want void my warranty. And talking to everyone, just adding a cold air intake won't improve your mpg.
just my .02
Dean
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 05-19-2007 | 06:54 PM
articfriends's Avatar
Make sure any filter you install (if you do it) has a multiple stages of filtration as single stage K&N type have been proven to have caused "dusting" of rings on ford diesels in some applications,not wirth the aggravation. Your probably not going to see a mileage gain either as your truck is most likely getting all the air it needs at part throttle already,Smitty
articfriends is offline
Old 05-20-2007 | 08:21 AM
Jassman's Avatar
Ive had 9 6.0's. By just adding a intake, you will actually see a performance loss on low end against a stock to stock run to about 70mph. After that you will only inch by the other stock truck by about 1/2 truck length. The factory filter is excellent for providing the perfect balance of filtration and breathing. NOW..if you add a cat back or turbo back exhaust and go with an SCT perf. tune, it's all relative. More air in and out mixed with the proper electronics works in harmony. My 07 dually tuned a 13.96 in its race tune, I use the aggressive stree tune and will run consistant 14.3's-4's, which is perfect for me. When I tow I just switch to the tow tune and tow what ever I want. The thing is not over abuse these trucks. They are trucks, not race cars. I see alot of people blowing trannies cause of poor electronics, where torque converters were not able to lock in, and hi temps in egt's due to over boosting causing puking, then engine gasket problems. My point is use them as a truck , enjoy the extra power, use it when needed, an occasional romp here and there, and they will last. To answer your Q. I have the mega 2 AFE. Turbo back cat delete into duals MBRP exhaust and a custom tuned SCT from Innvative Diesel. Good Luck. Jeff
www.dieselstop.com go to aftermarket 6.0 forum
www.innovativediesel.com talk with Eric for a custom tune
Jassman is offline
wrinkleface
5
09-25-2007 05:46 PM
Dean Ferry
16
03-26-2007 12:40 PM
tomcat
30
02-03-2007 07:06 PM
Rage
Nordic
2
09-27-2006 08:55 PM
Intolerant1
12
07-22-2002 05:20 PM
