Power steering problem >
Old 05-20-2007 | 03:58 PM
Cap206's Avatar
Registered User
Default Power steering problem
The power steering seems to have quit working.The pump is pumping,I took cable pin off of drive end and moved drive side to side. Steering wheel moves with about same effort with drive pin in or out.How hard should it be to turn wheel without the drive hooked up? 5.0 merc with aplha 1.I'm hoping for bad cable,but with my luck it will be the cylinder.Any way to check that cylinder out?Boat is 1988
thanks, Paul
Cap206 is offline
Old 05-20-2007 | 04:25 PM
yes if you take out the pin for the cable to the tiller arm with the engine running what you can do is take a prybar and push on where the other section of the cable is attached to the cylinder. what this does is actuate the cylinder to assist in your steering effort. you push it to the left or right and this will make the cylinder go in or out. if this does not work then the cylinder is bad. i have not seen those cylinders just not work unless they are rotted out or the lines are rotted out. but the age makes it possible.
lowfunds is offline
SteveB
1
09-16-2007 11:25 AM
redcorvetteman3
Chris Craft
2
07-05-2007 05:02 AM
Jupiter Sunsation
6
02-20-2006 09:15 PM
CHAOS REIGNS
5
12-11-2002 07:56 PM
Mate 229
Fountain
4
08-01-2002 09:41 PM
