Transom paint?
Old 05-23-2007 | 10:35 PM
24degrees's Avatar
Default Transom paint?
I'd like to paint my transom and I'm wondering if there is a paint that would look good brushed on?
Are the paints like Awlgrip brushable?
Thanks.
24degrees is offline
Old 05-24-2007 | 01:53 PM
CAPTAIN CHUCK's Avatar
I am not an expert but I am about to use awlgrip on my Outlaw and the distributor told me it could be sprayed or brushed with the same gloss finish achieved. I hope this helps.
Chuck
CAPTAIN CHUCK is offline
Old 05-24-2007 | 05:58 PM
24degrees's Avatar
Thanks.....
Old 05-25-2007 | 11:56 AM
madbouyz's Avatar
Awlgrip makes a different activator for brushing/rolling applications. I recently did a non-skiding job and decided to lick a coat in a storage bin while I was at it.
The area was properly primed but not too well sanded... I just slathered it on and a few days later I looked at it and 'holy chit !' I wish I had taken a few more minutes ... It really went up glossy !
A lot of yards have guys that use the 'roll and tip' method for Awlgrip and I hear you can almost compare them with some spray jobs .
madbouyz is offline
Old 05-25-2007 | 05:11 PM
MrCIG's Avatar
Charter Member#330
AwlGrip and Interlux can Both be brushed on and will look like they are sprayed. You have to use the proper Badger hair brush and take your time andapply a couple thin coats. The prep work is very important also. Make sure you do it when the temp is around 70 Deg and it will lokk just fine.
Mark
MrCIG is offline
SLINGSHOT
Detailing, Painting, & Fiberglass
8
09-06-2011 08:10 AM
Double R Performance
Nor-Tech
1
08-02-2006 11:34 AM
jackhammer
7
06-12-2006 08:53 AM
grimmy
7
05-07-2005 06:24 AM
