Help needed Pantera 28
Hi all,
I just bought a pantera 28 to restore, unfortunaley it has no drives or engines.
Advice on the kit i have to put in her would be much appreciated.
I am in the uk and gas here costs alot ! so no big crazy hp ( i would love to do that but just cant ) just a pair of stock engines.
Whats the best stern drive's for these hulls, ratios and so on?
Whats a good hp to have for this hull?
Here she is
http://www.boatsandoutboards.co.uk/view/ECB054
Thanks for your Help scud7
Here she is
You should post this in the pantera forum.
Do a search in the classifieds, engine section for the 383sbc from BAM marine. Two of those would be great as stock power for the boat. Also, try to figure out what the boat was rigged for before. Bravos would be the best to use for drives and w/ the smaller engines you wouldn't need X or XR.
I have been doing some research lately for engine packages acceptable to go overseas for Active Thunder.
If I were taking on the project you are about to, I'd probably go with a pair of the Mercury 6.2L engines mated to Bravo 1 XR outdrives.
http://www.brunswickmarineemea.eu/pr...$MCPS_MX6_2MH"
or
http://www.brunswickmarineemea.eu/pr...S$MCPS_MX6_2M"
You do not need Bravo1 XR drives behind small block power, (they are good for up to 600HP), but its not IF your drive breaks, its WHEN your drive breaks. Having the extra capacity in the drive is nice. Its ALWAYS the weak link (in this size/HP/range of boat).
You would be fine with Bravo 1X drives, but the XR gives you stronger drives for more longevity.
Are you considering outboards? Mercury Verado Outboards would be a nice setup as well.
Mercury Cummins diesel power may be another route you could investigate. Do some navigating around the Brunswick/Mercury Europe site that I linked above.
I would not go with twin Big Blocks like 496s or 502s. They would be IMPOSSIBLE to work on, and a pair of 320HP small blocks will likely give you almost the performance of two 375HP big blocks.
You would probably get a lot more info spending time in the OffshoreOnly Pantera owners' forum; but you will need to pony up some $$ to become a Gold or Platinum member to have access to this forum here on OffshoreOnly.
or
whats the price diff between the regular bravo (X?) and an XR?
Can a 6.2 even come close to breaking a bravo? Guys are running 600hp+ and don't break them... its all in how u treat them. so i'd imagine a standard would be fine w/a 300hp sbc, unless the $ is not really an issue or much of a difference.
I like the 6.2 as well. Jo at Pantera sold a 28 with the 6.2 - I believe it ran around 70mph. There are some pics of it in the Pantera section.
We have one on the 2004 Sea Ray. Sips gas pretty well - we can get two good weekends out of a 70 gallon tank - but we just cruise. We had an idler valve go out at around 280 hours. Not that much to fix, but I've never even heard of such a thing......
small blocks the 320s or 383model with a bravo or x or xr how much you want to spend. i had a stock 89bravo last 10yrs with between 580 and 650hp before it wore out it ran stock power from 89 to 95 95 to 05 with big power. and my replacement drive was parts drive with a 2'' shortie until it got stolen.
