454 Overheating.... HELP >
Old 05-29-2007 | 03:59 PM
I'm a fairly new owner of a 98 Baja outlaw with twins 454 Merc's. Over the weekend my passenger side motor started to run hot. Pegged @ 240. It was beached without pulling the drives up. I had a mobile repair $ervice guy replace my impeller which he said the original one was in great shape. He suggested maybe the thermostat was stuck causing it to over heat. I completely removed the thermostat and still continues to over heat
I pulled it off the water and hooked up the hose to the out drives and figured I could try to blow through out what ever sand it suck up. I disconnected a line on the thermostat intake and noticed not much water was going throughout the manifold. I turned up the water all the way and it got more water exiting but not in comparison to the out put from the other thermostat outlet on the other motor. Under the swim step the left exhaust outlet was running almost dry.
Back on the lake it ran cool for few minutes then overheated. I pulled off one of the lines from the thermostat manifold and it was just barley spitting out water now. The impeller is new and thermostat is out.
I really hate to take it to a shop and pay someone to figure this out. I'm assuming there is a clog somewhere. Maybe the sea strainer is if even has one. Is there a regular water pump in the engine like a car that is seized? How do you back water pressure the system? Any suggestions would greatly be appreciated
BAJAJIMI is offline
Old 05-29-2007 | 04:18 PM
BY U BOY's Avatar
pull the hose off the oil cooler and check for any obstructions.
It does have a water circ pump like a car. Check the weep holes for water.
BY U BOY is offline
Old 05-29-2007 | 04:41 PM
mats's Avatar
As said the oilcooler is the place to look. It has an inlet screen which eg old impeller pieces can not pass. If that is not the case I would look in the seastrainer or check the condition of the suction hose in the outdrive.
If no water comes out the exhaust, the circulation pump is not the likely cause.
mats is offline
Old 05-30-2007 | 09:18 AM
bcfountain's Avatar
Registered User
pull the drive off and look at the suction hose.they can unrivel from the inside and cause a loss of flow.mine looked ok from the frount side,but looking up inside reveled the hose unriveling.
bcfountain is offline
Old 05-30-2007 | 11:21 AM
BURNSMAZZ's Avatar
Not a good idea burying the drives in the sand.
BURNSMAZZ is offline
Old 06-04-2007 | 10:25 AM
Thanks for very much for the valuable info. I figured out the plumbing and back washed out the main line into the motor manifold and walla. Run colds again. Too bad it too me most the day to figure out the thermostat placement....I took out in a cluster of frustration when It was still running hot after the impeller replacement . I forgot it went into the top of the manifold not on block of the motor like a regular car.
Jim Decker
Lake Havasu Az
BAJAJIMI is offline
Old 06-04-2007 | 11:02 AM
BY U BOY's Avatar
Jim Decker
Lake Havasu Az
no problem glad you got it solved.
BY U BOY is offline
bajahaha
24
11-10-2007 11:22 PM
Dirthead
22
06-24-2007 05:23 PM
BAJAJIMI
05-29-2007 01:45 PM
Dirthead
33
01-14-2005 08:00 PM
Velocity24
7
06-17-2003 08:40 AM
