Am i running the wrong props? >
Old 06-01-2007 | 11:45 AM
Default Am i running the wrong props?
When I bought the boat, it had no props on it and the owner had a set of 25p mirages that he used to test the boat. I bought a set of 25 labbed mirages and Im only getting low 60's and 4000 rpm. What size should I be running??
twin 454's with bravo 1's.
Also, i have to really baby her while taking off from the dock because it wants to cavitate and just spin the props.
Where should I be with these? Shouldnt I be able to get closer to 4500 or 4800 rpm and 70mph? According to sunsation it had a set of 14x25's mirages from the factory and could run 70-72 stock.
Any help?
waterboy222 is offline
Old 06-01-2007 | 12:24 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Pretty boat! I love those MI boys.
25's at 4600 and 71 mph would be 2.2% slip. That's not going to happen. However, at 61 mph you are still under 5% slip and that is too good too.
Make sure your tach and speed are dead nuts and we can go from there.
23 Rev 4's would be a option. We can send some test props when you are ready.
Brett
[email protected]
bbladesprops is offline
Old 06-01-2007 | 01:58 PM
BURNSMAZZ's Avatar
What year is the boat,they usually prop all those Sunsations with Bravos.
BURNSMAZZ is offline
Old 06-01-2007 | 02:11 PM
throttleup's Avatar
Bravo I or Hydro P5-X props on the 32.
Julie
throttleup is offline
Old 06-01-2007 | 02:32 PM
Smile
Agreed the Bravo 1 propellers are far and away the most popular on this hull. But nobody has given the Rev 4 a chance. Beyond that, he's running under 5% now for goodness sake. (that needs to be varified)
These boats can be touchyyyy with chine walk. 5 blades can make or more often break the control.
[email protected]
Old 06-01-2007 | 02:39 PM
throttleup's Avatar
Agree Brett the drive heigth will have a hand in it but cup adjustments sure seem to help.
Julie
Old 06-01-2007 | 05:39 PM
So what could i expect with the rev 4's? According to hotboat and powerboat magazines in 93 when they tested this boat they were getting between 70 and 72 setup the same way i am and almost 80 with the mags. i did find the chinewalk though but a little trim settled it back down. With the rev4's will i see a higher speed and rpm or am i just as good as its going to get with the bravos and 454's?
oh, its a 93 model
Old 06-01-2007 | 06:21 PM
jryan26's Avatar
How fresh is the power? Does it sound like it is running smoothly? My last boat would foul plugs like a mofo idleing through dripping springs. Has it had a recent tune-up?
jryan26 is offline
Old 06-01-2007 | 07:29 PM
I wouldn't take the speeds numbers that you read in hot boat to the bank.
My advise would be to talk to Brett, he will lead you in the right direction!
Magic Medicine is offline
