White boat/black streaks
Old 06-02-2007 | 07:33 PM
Unhappy White boat/black streaks
I have a 38' powerquest (1995) when it is covered, and it rains the water will cause black steaks that are next to impossible to wash off. As I wash the water beads up. I have been using 3M products to rub, finish, and wax. The top of the boat rubs out good, but will not last. The entire boat will not hold up with the 3M products, any thoughts???? (sides look better than top)
TCH6868 is offline
Old 06-02-2007 | 10:22 PM
Have you tried wet sanding and buffing? I use meguiars car wax on my daytona.
If you decide to wet sand go with 1500 then 2000 then buff it will look like new! Then wax it a couple good times.
TravisB is offline
Old 06-13-2007 | 08:57 AM
Don't wet sand it, just buff it. Also lay your cover out and scrub that clean. I had the same problem with my cover and i washed it real good a couple times and then buffed the boat and haven't had a problem since.
Supraguy95 is offline
thedonz
07-27-2008 08:35 AM
pkspx
Detailing, Painting, & Fiberglass
4
05-10-2006 10:32 PM
Maritime_Eng
05-08-2006 02:21 PM
zog02
04-15-2005 11:15 PM
