go faster wax/paint
Old 06-03-2007 | 05:21 PM
Default go faster wax/paint
what is the best product to put on the hull to help at go faster
cheers
seamy is offline
Old 06-03-2007 | 05:43 PM
t500hps's Avatar
21 and 42 footers
This is going to be good!
t500hps is offline
Old 06-03-2007 | 05:45 PM
W A T E R !!!
Donzi38ZXXX is offline
Old 06-03-2007 | 06:24 PM
marineclean's Avatar
We did some testing a couple of winters ago on a solution. I picked this product up from a guy that swore it was ten thousand times slicker than cooking oil. I saw footage of his run and found it pretty dam impressive. He put it on a piece of metal and attempted a downhill land speed snow hill record. I have since lost his number, but I think he lives somewhere around Chicago. Try information for Clark W. Griswald. I think he might be in the food preservative business. Good Luck!
marineclean is offline
Old 06-03-2007 | 07:19 PM
masi242's Avatar
Just sand your bottom with 60 grit and let us know
masi242 is offline
Old 06-03-2007 | 10:22 PM
glassdave's Avatar
Neno the mind boggler
Originally Posted by marineclean
. . . Try information for Clark W. Griswald. I think he might be in the food preservative business. Good Luck!
ahh yes the semi permiable non-nutritive osmotic cereal varnish . . .it seals and protects the flake
08 OPA High Points Champion
glassdave is offline
Old 06-04-2007 | 05:36 AM
resurrected's Avatar
I saw the footage too.... very impressive
If it works on snow does not mean it will work on water
resurrected is offline
Old 06-04-2007 | 07:35 AM
what about graphite paint ive seen it used before but dont know how successfull it was
seamy is offline
Old 06-04-2007 | 12:31 PM
satisfactionII's Avatar
Mercrusier Blue. It adds HP to engines and makes the hull 'more faster' .
satisfactionII is offline
Old 06-04-2007 | 01:16 PM
Croozin2's Avatar
Originally Posted by marylandmark
The friction from the water will make whatever you put on there worthless after one run.
There was theory that a slightly rough bottom would cause tiny air bubbles to reduce friction but think that would be some race boat stuff- searching for that last .0012 of a MPH...
We actually used to do this when I raced outboards. Prime the bottoms with a good (PPG etc) epoxy primer and wet sand progressively down to 1500. Can't verify if it actually makes a ton of difference but as was stated, when you are looking for tenths and hundredths, you never know. This was on 450 to 550 lb Allisons, Hydrostreams and STV's.
Croozin2 is offline
