hydraulic steering and gimbal bearing >
Old 06-04-2007 | 07:29 AM
Default hydraulic steering and gimbal bearing
Can an improperly installed dual-ram hyd. steering system cause accelerated gimbal bearing failure? I installed the system myself, works perfectly, but shortly after the install the gimbal bearing failed (although I had about 200 hrs on the drive by that point) and now, less the 50 hours later, I'm pretty sure it's going again. I'm wondering if the rams are slightly off alignment/height/whatever and that might be causing extra stress on the gimbal? Thanks.
bouncedcheque is offline
Old 06-04-2007 | 07:38 AM
no! gimbal brgs rarely fail unless they get water on them
JIMG is offline
Old 06-05-2007 | 05:57 AM
East Coast B's Avatar
I agree, don't think the external positioning will play a part in this. Be it your new steering or your old steering, the drive is moving up down left right irregardless of what your using to move it. I'd look internally at condition of parts/shaft running through bearing, bearing seating, engine alignment, water.
Good luck!
East Coast B is offline
Old 06-05-2007 | 07:21 AM
Thanks for the help.
bouncedcheque
9
08-15-2005 06:34 AM
Ran-Dom 32
22
03-24-2005 09:28 PM
CN24
4
01-15-2005 07:25 PM
Bankshot242LS
6
05-09-2004 04:18 PM
Bankshot242LS
04-23-2004 01:50 PM
