ideas on carb size for my 502 ??? >
Old 06-04-2007 | 08:06 AM
Default ideas on carb size for my 502 ???
Hey geys ive got a 26' profile with a 502 that the last owner says is running over 600hp. ive been into it far enough to see it has a solid lifter (noisy) roller cam, blue cast alum. roller rockers, and full 4 into 4 marine headers. i have no idea on any specs but it has a beautiful loap on idle so it must be a pretty big stick!!! with the 1050 dominator it would run mid 80s at about 5300-5400 rpm. but that carb was not user friendly and even after a full rebuild made the back of the boat black in one outing!! so i tryed a 850 double pumper with 84 jets at all 4 corners and its a new boat. i like every thing about it but the fact that ive lost 4 mph on top and 400 rpm. does the 502 at 5300 need more cfm or do i start playing with jeting?? the back of the boat still gets a little black after time but that could still be rinsing out of the mega tips and what hopped up motor doesnt make a litte carbon??
paulkairis is offline
Old 06-04-2007 | 12:46 PM
That should be plenty of carb. I would start looking at jetting.
Did you switch intake manifolds to accomodate the new 850 also?????
Griff is offline
Old 06-04-2007 | 01:10 PM
Croozin2's Avatar
If it's putting soot on the transom at idle that can be adjusted out with the idle air screws. If it's making the transom black at cruise speeds it's waaaayyyy too rich or you have another problem (blown power valve, high float level etc). You need to make a good hard WOT run and take a plug reading.
Croozin2 is offline
Old 06-04-2007 | 01:17 PM
i did swap manifolds also, as far as the soot it seems to be after a hard run. thats what makes me think im still rinsing out the mufflers?? i see in here that a guy was running 80s up front and more like 90-92s out back, may be i'm starving it on top end. i'll have to read the plugs like you say. by the way whats everybodys favorite plug for this set up, i don't trust the last guy on anything any more!!
Old 06-04-2007 | 10:36 PM
cuda's Avatar
Those jets are smaller than the stock secondaries on a carbed HP 500.
cuda is offline
Old 06-05-2007 | 12:33 AM
Are you running powervalves in both the primaries and secondaries. When a powervalve opens, it is like opening another a jet and adds the equivalent of 6-10 jet sizes. The HP 500 carbs don't run a secondary PV so the secondary jets are much larger than the primaries.
Griff is offline
Old 06-05-2007 | 06:13 AM
i dont think there is a power valve on the back?? i'm pullin the motor today to do the bottom end i'll check
Old 06-05-2007 | 11:21 AM
If there isn't one in the secondaries, you need change jetting to about 80's in the front and 90's rear and dial it in from there. Take plug readings at max cruise speed, just before the secondaries open, to adjust primariy jets and at wot for the secondaries.
Griff is offline
Old 06-06-2007 | 03:29 PM
Get this, the thing has a power valve in the front and not in the back ?? with 84s at all corners!! did he maybe get the fr. and back blocks turned around, the only dif. i see is a plugged vac. port on the frt m. block?? with a big bump stick i'm probably not running much vac. am i better off to get rid of the power valve and just jet the thing??
Old 06-06-2007 | 07:59 PM
cuda's Avatar
The jets on an HP 500 are:
Primaries 75 & 80
Secondaries 89 & 93
No power vavle in the secondaries. Holley #9022.
http://www.mortec.com/carbs.htm
cuda is offline
