Oil type and level for fuel pump housing >
Old 06-04-2007 | 09:49 AM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
Default Oil type and level for fuel pump housing
I have HP500 motors with the belt drive fuel pump what type of oil should be in the housing and how much?
I saw there is a side plug in it and am thinking you just fill to that level.
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 06-04-2007 | 10:23 AM
Wally's Avatar
Were doomed!
yep...there should be two plugs...one to fill(top) and one to drain(bottom)
fill w/90w oil and good to go
-Wally
Wally is offline
Old 06-04-2007 | 07:21 PM
trips2win's Avatar
my 98 500s only have one plug i seperate the fuel pump wipe out the fuel and oil and fill with gear lube to plug bad design.
trips2win is offline
Old 06-04-2007 | 07:39 PM
Mine only had one plug as well. I could take out most of the bolts on the seapump bracket and tilt it enough to get out 95%of the lube. I've always used Merc Hi perf gear lube aka drive lube.
Griff is offline
Old 06-04-2007 | 08:59 PM
mtgbiker's Avatar
Mercruiser Spec Says Hi-preformance Gear Oil
mtgbiker is offline
Old 06-05-2007 | 08:49 AM
klaw's Avatar
mine was the same one hole in the side of resevoir
Removed fuel pump was rebuilding water pump also so just removed whole assembly and then emptied it out and then used royal purple synthetic
klaw is offline
alecsammy
0
09-21-2008 09:47 AM
Thunderstruck
0
07-25-2006 01:10 AM
ratman
04-17-2006 03:11 PM
Active Mike
7
07-03-2004 10:13 AM
Nordicflame
4
03-04-2004 10:21 AM
