500hp  Gurus !!! >
500hp Gurus !!!
500hp Gurus !!!
Old 06-06-2007 | 02:13 AM
Default 500hp Gurus !!!
I am buying a 2002 Gen6 500hp and wanted to know the (easiest) best way to get 500 to 550hp. Also what is it stock. Thanks in advance.
speediseverything is offline
Old 06-06-2007 | 07:02 AM
Canada Jeff's Avatar
heads and a cam. it's EFI so resurch who has done this and go with an experienced builder. I have tried the external add on crap for the EFi and nothing reall works.
Or do what I did over the winter and Whipple it !
Canada Jeff is offline
Old 06-06-2007 | 07:40 AM
Is is EFI or carb..could be either one....if carb..you might consider a 250 blower setup, run about 4psi or so..you could also do some porting on the heads like Jeff suggested and prob gain nearly 50hp..not sure if I would touch the cam or not..those HP500's have great cams in them that work very good and no rev problems, but that is also a choice...btw..stock hp is 500 @ the crank and 470hp @ the prop
After thinking about it..I guess you could only have a efi...carb was made until 2000 and efi started in 1999...so maybe the head work would be a good choice...OR THE WHIPPLE!
Bajapred is offline
Old 06-06-2007 | 07:46 AM
Stock power for a HP500 is 470 hp.
Tyler Crockett redid rebuilt both of mine recently.. basically heads, cam, ignition.. dynoed out at 585 hp at 5600 rpm.
Carder is offline
Old 06-06-2007 | 07:49 AM
Bajapred is right, stock power is 500hp, not 470.
I didn't think Merc still built the carb version in 2002.
Old 06-06-2007 | 07:56 AM
jdnca1's Avatar
The quickest and easiest path to 550HP.... well take off the EFI system and intake and sit it on the shelf....then bolt on a single plane and 850 and spin the motor 5800....and yes, I am being serious....If you're going to SC, no need to stop at 550....go whipple or roots with carbs and put up 800+ reliably....
jdnca1 is offline
Old 06-06-2007 | 08:01 AM
I didn't want to lose my efi, if he's anything like me, he won't either. What about just swaping out to Aluminum heads? That should be good for 40 hp.....no?
Old 06-06-2007 | 08:23 AM
razor1115's Avatar
Carder,
What speeds are you seeing? What is your set-up?
razor1115 is offline
Old 06-06-2007 | 11:59 AM
I am told it is a 2002 but it has a carb, This motor is going in an Advantage Citation 22ft. It has gil exhaust right now.
Old 06-06-2007 | 12:14 PM
Don't waste money on the exhaust, you won't get any more hp. Those Gil's flow great.
If it's a carb, you have alot of options open to you.
If I were you I would fine a good engine guy close to you, check him out (talk to his customers) and then ask him what he would recomend.
