Compression ratio with 049 heads >
Old 06-07-2007 | 08:19 PM
Default Compression ratio with 049 heads
Will I be ok with 9.4CR?
jackhammer is offline
Old 06-10-2007 | 09:52 AM
More info needed? The heads are worked and have the larger valves (2.19/1.88) so those flow numbers are off a little.
I've already got the parts so I'm sticking with it... the real question should be if 9.4 is a tad too high should I use a thicker head gasket to bring it down a few tenths?
The boat will live on a trailer so I should have regular access to 91 octane.
Attached Thumbnails Compression ratio with 049 heads-049-stock-flow.jpg   Compression ratio with 049 heads-isky-rr275-284.jpg   Compression ratio with 049 heads-kb787.jpg
Old 06-10-2007 | 07:29 PM
What Octane are you planning on running?
1BIGJIM is offline
Old 06-10-2007 | 08:20 PM
I'd like stay with 91.
The answers I'm getting from the machine shop and valve train guys is a reserved, "I wouldn't go any higher than that". The guys at strokermotor.com said I shouldn't go to 9.4... they wanted me to stick the 3cc flat top and run 87 octane (or get aluminum heads).
Old 06-11-2007 | 06:12 AM
I would not with iron heads.
If you do be conservative with the timing.
You need to ask yourself is it worth the chance?
1BIGJIM is offline
Old 06-11-2007 | 09:10 AM
I can play with timing at the dyno... couple degrees on the safe side then. I can also choose a little more gasket volume when I know the exact deck height. I can probably get it down to 9.1. We also have 93 octane here, but no telling how much longer it will be at the pumps.
Old 06-11-2007 | 09:22 AM
Here's a damn good article which really helped me understand compression ratio.
http://www.carcraft.com/techarticles...ression_ratio/
I've never seen it put in as simple terms.
"Compression ratio is the relationship of cylinder volume (or displacement) with the piston at BDC to cylinder volume with the piston at TDC. If the volume of the cylinder with the piston at BDC is 10 times greater than the volume of the combustion area with the piston at TDC, then 10 units of volume get squeezed into 1 unit of space, and the compression ratio is 10.0:1"
Old 06-11-2007 | 09:36 AM
That is until I used this calculator on the KB site. I understand how cam timing effects CR (intake valve not closed at exactly BDC), what I don't understand is how a rod length can effect stroke!? In my mind a 4.25" stroke is a 4.25" stroke... even if you put a 10 foot rod on it the stroke will still be exactly 4.25". I may have to call KB to get this one explained.
Old 06-11-2007 | 09:37 AM
mtgbiker's Avatar
I had the exact same concerns last year building my motors using the "990" heads. My compression worked out to be 9.3/9.4. The same size valves were also used. For whats it worth, I have had no problems running 91-93 octane at 36* timing. Go with it!
mtgbiker is offline
Old 06-11-2007 | 05:37 PM
mtgbiker's Avatar
JackHammer,
What H.P. are you looking for?
and,
Where do you want the torque range?
What cubic inch motors are you starting with? 454's?
IMHO, You may want to mirror the cam specs for the HP500 carbed motor. Also, was a head flowed to your intake (dual/single plane?) to decide on cam choice?
I've made a few mistakes in the past and don't mind sharing what not to do!
mtgbiker is offline
