TRS transmission
Old 06-09-2007 | 07:32 AM
Default TRS transmission
Anyone have a Merc Tran transmission for a 454/TRS setup?
Scuba Steve is offline
Old 06-09-2007 | 11:34 AM
stageharbor's Avatar
Go Big or Go Home
Call Kirk at Kc marine 360 738 3100 kcmarinetr.com
stageharbor is offline
Old 06-09-2007 | 04:39 PM
If you can't find anything locally try:
Doller Marine
BAM
Cobra Power
T N T
Speedmasters, Inc.
Edward R. Cozzi is offline
Old 06-09-2007 | 06:01 PM
Nykamp's Avatar
I have a totally rebuilt BW C 72 for sale, it's over kill for a stock 454, it's built for 900 +hp, it's built the same as the drivelines that are behind my 1000 Zul's.
Nykamp is offline
Old 06-09-2007 | 06:23 PM
Only trouble with using the BW is if he's already set up for the MercTrans he has to move the engine forward almost 18 inches.
Old 06-09-2007 | 06:33 PM
el indio's Avatar
i have a ton of trs stuff.......p.m...
el indio is offline
Old 06-09-2007 | 08:55 PM
[QUOTE=speedo;2157072]you might be referring to a 280 trans. trs trans is a red label b/w.but then again you are the surveyer..
It certainly doesn't mean I know everything!
To me a "MercTrans" is the smaller aluminum-case with the Ford C-6 guts.
If your post was a shot at sarcasm, I sure hope you're correct.
Old 06-09-2007 | 10:17 PM
el indio's Avatar
hey eric arent you that golf goof....trs was used everywhere with all kind of power.is the transmission built into the bell housing[as ed assumed] or a seperate casting.the answer will be very helpfull.......m.m.....P.S.trs was very popular and successful.if you doubt me ask the folks at KONRAD.right Biggus?
el indio is offline
Old 06-09-2007 | 10:34 PM
I've never seen or heard of ANY BW being called a "MerTrans".
No, Eric, you ARE a prize!
Old 06-10-2007 | 12:03 AM
el indio's Avatar
hey ed cozzi..its been 30 years since the first roy halman memorial fun run to michigan city.wow 30 years,like yesterday.....m.m......roy was ahead of his time........
el indio is offline
