An easier way?
Old 06-11-2007 | 09:54 AM
JLAY's Avatar
Default An easier way?
I finally moved into my new house last weekend. The boat actually fits in the garage, the only problem is that it took three of us to push it in. I can't just back it in because it has to go on an angle to fit. It was a ***** to push sideways! Is it just my trailer or all tandem trailers like this. If so does anyone have any ideas how to make it easier. Thanks.
JLAY is offline
Old 06-11-2007 | 10:15 AM
Scott's Avatar
Charter Member #30
I Spray a mix of soap (Dawn) and water on the floor and tires to push it sideways. I also use my Tractor but I'm pushing a 38' boat so no way could 3 guys do this. May want to buy an old lawn tractor like a late 60's or early 70's that has the weight behind it to help out
I have Steps & Bubbles!
Scott is offline
Old 06-11-2007 | 02:25 PM
JLAY's Avatar
Thanks! I never thought of lubrication. Lubrication makes everything better!
JLAY is offline
Old 06-11-2007 | 02:28 PM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
have you seen these?
http://www.griotsgarage.com/catalog....3030&SKU=77749
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 06-11-2007 | 04:45 PM
cuda's Avatar
I have a 22 Donzi that won't fit straight in my garage, but the back twelve feet are walled off for a workshop, with insulated walls, and ceiling. I sawzalled a hole in the wall, then built a dogbox in the workshop to enclose the outdrive. It should work even if the dogbox is outside on the ground. I built it out of some left over starboard I had, and one peice of plywood. Looks like a freezer from the starboard side.
Attached Thumbnails An easier way?-6-10-005.jpg   An easier way?-6-11-001.jpg   An easier way?-6-11-007.jpg
cuda is offline
Old 06-11-2007 | 05:48 PM
All you need is a powered trailer dolly:
http://www.powermoverinc.net/htmls/pmaccarts.html
MacGyver is offline
Old 06-11-2007 | 06:38 PM
Jassman's Avatar
http://www.powercaster.com/products.html
here is another company, I dont know which is better. Jeff
Jassman is offline
Old 06-11-2007 | 06:45 PM
If you check eBay, one is for sale right now.
MacGyver is offline
Old 06-11-2007 | 08:40 PM
Cattitude's Avatar
ball on the front of a pickup/jeep/tractor zero turn mower
Cattitude is offline
Old 06-11-2007 | 09:06 PM
those are cheaper route than a used forklift....
open87 is offline
