Cutting stainless???? >
Old 06-13-2007 | 02:11 PM
CAPTAIN CHUCK's Avatar
I am making a couple of things out of 1/2" solid stainless rod. What I need to know is what kind of drill bit will bore through stainless, for some cotter pins, and what is best for cutting it? Thanks.
CAPTAIN CHUCK is offline
Old 06-13-2007 | 02:27 PM
cougarman's Avatar
Regular Drills work fine, key is lots of coolant and or some sort of oil.
Try not to let it heat up that's when your day starts to go bad.
Jon
cougarman is offline
Old 06-13-2007 | 02:30 PM
Thanks Cougarman I will just use my titanium bit set. I am guessing a band saw will cut it.
Old 06-13-2007 | 02:43 PM
cougarman's Avatar
Yes band Saw will work, Few years back I had 7' of 6" round stock stainless steel.
I cut it all up and precision ground it and made a full stainless steel dumb bell set. There all in 2 1/2 pound increments from 5 lbs. to 45 lbs. Heads are all welded on to stainless steel handles. Numbers were all CNC cut into the heads of the weights
LOL...They are the most accurate set of dumbells you will ever find. Got tired of making them, lot of people have tried to buy them from me. ;-)
Anyways I cut it all with a coolant feed band saw.
Stainless is actually soft, but it's gummy and thats why its hard on tooling.
Jon
Old 06-14-2007 | 09:31 AM
Big Block Billy's Avatar
Cobalt steel drill bits. A cut off blade can also be boat for your 4.5 " disc grinder and cuts like butter. BBB
Big Block Billy is offline
Old 06-14-2007 | 09:33 AM
Exclamation
Also when drilling stainless , push hard and low speed to avoid burning out drill bits. Get some tapmatic cutting fluid Patience is key ! BBB
Old 06-14-2007 | 03:14 PM
Thanks guys.
502ss
9
10-16-2007 03:20 PM
TCOUTLAW
1
06-28-2007 12:10 AM
nocigarette
19
09-12-2006 09:05 PM
Dave M
5
04-08-2003 09:39 PM
Raypanic
10
08-09-2002 02:19 PM
