How do you check the ignition timing?
What year engine? What ignition system? If it's a thunderbolt IV or V, look for a purple wire with white stripe coming from the dist. that should have a female connector with a rubber plug in it- plug comes out and you ground that wire. If it's EFI, you jump pins A and B together on the data port connector.
It is a thunderbolt IV. It has a white wire with red strip and a white wire with a green strip on the back of the distributor. Where is the purple? My boat is not EFI. Carb and normal easy to work on.Thanks
