Stroker crank install >
Old 06-16-2007 | 11:52 AM
Default Stroker crank install
Look at the poor crank! I couldn't believe my eyes! I've seen cranks with 1 hole or 1 plug, but this is beyond my comprehension. The picture doesn't show the extent of the holes very well... they are different diameters at different depths. The flywheel had material removed as well.
One thing for sure, right or wrong, the guy spent a lot of time on this.
www.strokermotor.com
DES DG3-425 4340 Nitrided BB Chevy 496, Ext. Balance, 4.250" Stroke, 2.20" Crank Pin, 6.385" Min. Rod Length, 2pc Rear Seal
jackhammer is offline
Old 06-16-2007 | 12:06 PM
Also, everybody and their brother told me I was going to have to clearance the block. I wanted to do this before sending the block for a bore, so I just layed it up there (with some bearings and oil) and went to start marking off where to grind, and, and, and, I can't find anyplace to clear?? there's at least an eighth inch clearance here. Are these H rods that much smaller? Or am I missing something?
Old 06-18-2007 | 10:27 AM
4.25" in a BBC stock block does not need to be clearanced.
evelkevin is offline
Old 06-18-2007 | 12:33 PM
Mine did.
1BIGJIM is offline
Old 06-18-2007 | 08:14 PM
I'm guessing the "I" Beam rod with the thru bolt and nut need the clearance work. I don't have one handy to compare, but the H beam appears to be a lot smaller in that area. If so, it's good info for the next guy... either pay $ to clearance the block or pay $$ and upgrade to H beam rods. If you need longer rods anyway then it's a wash.
Old 06-19-2007 | 09:26 AM
Originally Posted by 1BIGJIM
Mine did.
Mine didn't.
ghittner is offline
Old 06-19-2007 | 10:10 AM
Originally Posted by ghittner
Mine didn't.
My machine shop which does mainly does race car motors, hundreds if not thousands a year told me that some block castings need it and some don't, even from the same generation/year/etc. The only way to know for sure is to mock it up, or clearance it anywho.
jmherbert is offline
Old 06-21-2007 | 11:40 AM
jmherbert:
Who is your machine shop?
vtec is offline
Old 06-21-2007 | 01:11 PM
I had to notch the block AND take about a 1/4 inch off the crank throws then have it rebalanced.
kennyo is offline
Old 06-22-2007 | 06:19 PM
kevinr's Avatar
Registered User
balance man should have tried to make it a internal bal. or lathe off the counter
kevinr is offline
