Help identifying outdrive
Old 06-17-2007 | 10:03 PM
Default Help identifying outdrive
I have an outdrive that is on a 24' Searay that I need help properly identifying. The motor is a GM 350 V8 255 HP engine # 4499138, it has a velvet drive transmission model # MCM-C serial #09817, the prop is about 19 3/4". I believe this is either a TR, II-TR, or possibly a TRS. I am having to replace the lower housing, part # 1641-4854, and will have to replace all the bearings and seals. For me to order the seal and bearing kit I need to know excactly what I have. I have been all over the outdrive and cannot find any numbers any where. Thank you. If more info is needed please advise at to what you need.
cricketsman05 is offline
Old 06-17-2007 | 10:07 PM
tblrklakemo's Avatar
SeaRay Sundancer
need more info
tblrklakemo is offline
Old 06-17-2007 | 10:27 PM
Biggus's Avatar
Sounds like you have a TR drive ( ability to swing a 20" prop) with a MercTrans. They were popular on older Sea Ray cruisers. If you have a hard time finding parts, the Konrad 520 is a direct bolt-on.
www.konradmarine.com
[email protected]
Biggus is offline
Old 06-18-2007 | 07:17 PM
jhiguy377's Avatar
I don't think it would be a MercTrans if its bolted to a Velvetdrive. I agree w/biggus that its probably a TR if its swinging a 19 3/4" diam. prop.
jhiguy377 is offline
wet_rat
Drives and Lower Units
5
10-15-2007 04:22 AM
dean51267
05-02-2007 01:59 PM
articfriends
Prop Talk
4
09-11-2006 08:35 PM
pullmytrigger
3
03-24-2006 11:49 AM
MIdnightRider
Cigarette
4
04-12-2003 02:54 PM
