H20 & Oil Don't Mix
I am looking for a possible cause for having milky oil on top of the metal tray that holds the lifter guides in place. The starboard side head had a little milky residue on two rockers. The port side is ok,no milky oil. I had just changed the oil, no apparent water in the pan. I checked it again now still no sign of water in the oil pan.
Any ideas?
Any ideas?
Thank you for the input. Does anybody have any suggestions as to how to proceed. Do I start by pulling the intake to check for leaks? I'm still a bit confused by the only seeing the milky oil in the valley and on the rockers. I just don't want to damage another motor.
I would pressure check the water system. I pulled the line off the sea pump and put a plug in it. Then pulled the two lines off the exhaust and plugged one of them. I used a standard radiator pressure checker with a couple adapters and a hose clamp to check it. Most boats have water coming in one hose and out two smaller ones at the exhaust.
I don't know what the oil temp is at. I did hear that it could be condensation but I was a bit concerend when I pulled the breather line off of the valve cover and a little water came out of it. It just seems a bit excessive for condensation I think but am not sure.
just had all the same symptoms and it was an intake gasket, and a head gasket. changing the oil and running kept the oil clean, but running it for the day filled it back up with water. two very slow leaks. under when the r's went up they leaked more. did the leaky intake ran it in the yard for a couple of hours and all was good. put in the water and after a day same issue. Good luck
