Installing a transom mounted pickup? >
Old 06-18-2007 | 04:20 PM
Registered User
Default Installing a transom mounted pickup?
It was suggested I post this here in the tech section to see if I can get any input on this....
I goofed last weekend while out at the islands, I wasn't paying close enough attention, & drifted over a shallow sandbar. Cooling system got "PACKED" with sand. I got lucky though, it didn't go past the T-stat, & had it all cleaned out in about 30 mins (I'm so thankful Donzi set their engines so one can work on them quite easily)...anyway. I found several old threads on this unfortunate event (so, I didn't feel completely like an idiot ), but they all seemed to head in the direction of installing a transom mounted pickup. I can see how this would help, but what do I do with the pickup in the drive? I read where folks have used this as a drive shower, how is that done? I also saw one post saying there may be possible problems on a stepped hull. I went on the Stainless Marine site, they have some very nice set-ups, but not sure what size I would need to go with....Anyone got any tips on do's & don't's or am I just wasting my time with this, & should just really pay closer attention to the depth?
rangerrick63 is offline
Old 06-18-2007 | 06:40 PM
monstaaa's Avatar
its during the season,,,, pay more attention. address it over the winter.
monstaaa is offline
Old 06-18-2007 | 08:39 PM
Elite Marine's Avatar
Agreed!!!
Elite Marine is offline
Old 06-19-2007 | 07:37 PM
Codered's Avatar
If you go to a transom mounted water pickup for engine cooling water can you block off the water pickup in the drive all together Mine is almost corroded shut. Will blocking off the drive pickups cause the drive to run hot or overheat
Codered is offline
Old 06-19-2007 | 11:42 PM
Get a dump for the drive water. Heat kills bravo drives. Keep the water flowing through it. Its very simple to install an angled dump that will act as drive shower.
Griff is offline
Old 06-20-2007 | 12:25 PM
Codered's Avatar
The fitting inside the transom is 95% blocked by corrosion thats why I am going to a transom mounted pickup.
Codered is offline
Old 06-20-2007 | 02:10 PM
Fix the corrosion problem then?????
Griff is offline
Old 06-20-2007 | 02:25 PM
Pat McPherson's Avatar
I'd add a sea strainer not a transome pickup.
Patrick
Pat McPherson is offline
Liquid Life
Do It Yourself, Boating on a Budget
3
06-17-2008 03:11 PM
rangerrick63
06-19-2007 06:25 PM
Daddio
0
09-03-2004 11:17 AM
djm
6
04-18-2002 02:35 PM
