Old 06-20-2007 | 09:56 PM
mbones's Avatar
mbones
Default ???????????????
i have one engine out of my boat. pros and cons to putting a drain line with valve or plug on the bottom of oil pan so you can pass it threw the drain plug to change oil.no mess??
mbones is offline
Old 06-20-2007 | 10:08 PM
Expensive Date's Avatar
I have them on my boat They were put in by the dealer when I bought my boat.They kinda scared me at first but they don't leak
Expensive Date is offline
Old 06-20-2007 | 10:11 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
No cons. All pros. Definitely go ahead and install it.
The only issue is when you pull that plug, even after draining all the oil out via the dipstick, you are still going to have roughly 1/2 to 3/4 of a quart in the pan that is going to come out of the drain hole. Be ready for this mess.
Sydwayz is offline
Old 06-20-2007 | 10:47 PM
Registered User
No cons. all positive. It was the cheapest thing I ever did to my boat, that saved me the most time and effort. No pump no mess. Oil goes outside the boat. etc etc. You will be really glad that you did it every time that you change the oil
the duke is offline
Old 06-20-2007 | 10:54 PM
tblrklakemo's Avatar
SeaRay Sundancer
I love it. Get the boat out of the water after a good run and open the fill cap, pop a hole in the filter, and snake the drain tube out the transom and as far down into a bucket or whatever you want to use. Come back in an hr and its empty....completely.
tblrklakemo is offline
Old 06-20-2007 | 11:51 PM
jhiguy377's Avatar
I have those on my boat; I do however keep the hoses elevated, just feel better about it - Jeff
jhiguy377 is offline
Old 06-21-2007 | 06:57 AM
excursion's Avatar
I did see one bad thing once with them, the fitting that goes into the oil pan is BRASS and it had a crack in the fitting. Luckly is was a slow leak and he found it. If it had split all the way at 5000 rpm motor would not have lasted long.
excursion is offline
Old 06-21-2007 | 07:51 AM
GLH's Avatar
GLH
I have one on each mills on my rig.
That's the way to go.
GLH is offline
Old 06-21-2007 | 11:47 AM
StraightJacket's Avatar
One one boat we have them so we feed them threw the bilge plug hole to change out the oil, and the other we have hooked up to a Holley blue with valves to pump out the oil.
StraightJacket is offline
