safe timing? >
safe timing?
safe timing?
Old 06-22-2007 | 01:39 PM
BY U BOY's Avatar
Default safe timing?
What is the max safe timing i can use on a 7.4l with the gm performance aluminum heads,10:1 compression wich i think the heads bump up to 10.7:1, and the zz502/502 cam. running 93 octane.
heads are
combustion chamber 110cc
runners are oval 290cc
cam specs are
224*/234*
.527/.544 at 110 lsa
Thansks.
BY U BOY is offline
Old 06-22-2007 | 02:42 PM
OldSchool's Avatar
34 total advance, I wouldn't any higher than 36.
OldSchool is offline
Old 06-22-2007 | 02:51 PM
jdnca1's Avatar
jdnca1 is offline
Old 06-22-2007 | 03:23 PM
unless you have modified your pistons or deck height you're not at 10:1 and definatly not 10.7:1 on a 454.
with a 110cc combustion chamber and a stock pistion that still sits .020 in the hole you're around 9.5:1.
In any case 36 is still where you wanna be.
DAVE
Dave F is offline
Old 06-22-2007 | 04:05 PM
BY U BOY's Avatar
DAVE
Im running the srp 10:1 dome pistons.
Is there a way to check what my compression really is?
BY U BOY is offline
Old 06-22-2007 | 06:58 PM
monstaaa's Avatar
32 degrees is safe. 34 is ok as well , but with all the ethanol in the fuel these days,,,, .
monstaaa is offline
Old 06-22-2007 | 07:52 PM
Pwrbt33's Avatar
You never know where you might be and need gas and all you can get is crap, I like the 34 mark myself. Especially if your not an all out need every ounce of HP you can get kinda guy.
John
Pwrbt33 is offline
Old 06-22-2007 | 09:00 PM
Ah! Now it makes sense. As far as calculationg CR your piston card should have the amount of cc's it is at TDC. In your case it may be a negative number.
your head gasket will say the same on the package. If you're using a fel pro 1037 I believe thats a 10.9 cc and lastly you already know your head is a 110.
So with a piston volume of:
-20cc = 10.7:1 @ 96cc total
-15cc = 10.2 @101
-10 = 9.8 @ 106
Just to give you some rounded figures
DAVE
Dave F is offline
Old 06-22-2007 | 09:56 PM
t500hps's Avatar
21 and 42 footers
I have no idea...but my builder wanted it at 32 so there would be no problems!!!!!!
t500hps is offline
Old 06-22-2007 | 10:08 PM
BY U BOY's Avatar
-15cc = 10.2 @101
-10 = 9.8 @ 106
DAVE
thanks ill look for that info.
BY U BOY is offline
