Oil pan size for 496 stroker >
Old 06-26-2007 | 08:00 AM
Default Oil pan size for 496 stroker
Are these 8 quart pans? They came off my 454's that are now stroked to 496.
I didn't have clearance issues, will I have capacity issues???
Attached Thumbnails Oil pan size for 496 stroker-oil-pan-1.jpg   Oil pan size for 496 stroker-oil-pan-2.jpg
jackhammer is offline
Old 08-11-2013 | 05:43 AM
Craney's Avatar
I'm building the same motors and have the same questions will my stock oil pans work?
Craney is offline
Old 08-11-2013 | 11:02 AM
most steel rods will clear stock pans with a 4.25 stroke crank...but ck by turning engine over before bolting the pan on
ezstriper is offline
Old 08-11-2013 | 10:51 PM
My steel pan cleared with no issue. I think it will come down how far the baffle sticks up.
f_inscreenname is offline
Old 08-12-2013 | 10:50 AM
Those look to be 6 quart pans to me. The GM 8-quart pan has a sump that comes within about 4 inches of the front. These were commonly installed on heavy trucks by GM - a friend of mine always called them the "school bus pans". Smaller pan will probably clear, but with the increased windage produced by the longer stroke, you might want to consider additional capacity and some type of windage tray. Would hate to see you have oil pressure issues after building and installing a brand new engine.
Budman II is offline
Old 08-12-2013 | 11:11 AM
vintage chromoly's Avatar
A good pan is cheap insurance!
I'd buy an 8 qt. at the minimum. Get a nice baffled pan made for offshore conditions.
Forget the windage tray and use a crank scraper.
vintage chromoly is offline
Old 08-12-2013 | 01:44 PM
kaama82's Avatar
Whatever you do, dont buy a Canton pan..... I ran them on my stroked 496's in my old Scarab. The oil pressure was fluctuating all over the place above 4000 RPM. Made One change, bought 2 new Gil pans and the problem was solved.
kaama82 is offline
IRONMAN
Do It Yourself, Boating on a Budget
2
02-26-2008 09:00 PM
Westcoast
01-22-2008 08:51 PM
253checkmate
2
12-24-2007 01:44 PM
ajs67Donzi
5
09-24-2006 07:03 PM
StrikinLightnin
45
09-05-2002 08:57 AM
