Help with 496 Mag HO >
Old 06-26-2007 | 10:27 AM
racer-x6's Avatar
Default Help with 496 Mag HO
Need some help, when trying to get up on plain motor will run fine for about 30 sec.and then go in to gard. mode and alarm sound. If I turn the key off and re-start the alarm is gone but will do the same thing. water /temp press ok, oil pres/temp ok, drive oil ok. the only code it gives is over speed(rev.) If I stay under 3000rpm when trying to get up it will run all day long. I can not find any sensor for the over speed other than in the ECM. the tach does not show above the max rpm and I have changed the prop hub.(It has no slip) Every thing is the same as last year (prop, drive, ect.)
Any thoughts?
racer-x6 is offline
Old 06-26-2007 | 11:00 AM
txriverrat2001's Avatar
Depending on the scanner you may or may not get the code for low water pressure. But - generally the scanner will provide you with the amount of water pressure. Check that again...
txriverrat2001 is offline
Old 06-26-2007 | 11:16 AM
racer-x6's Avatar
The Freeze frame snap shot say's overspeed at 745 rpm , that can't happen. W/P was good. Merc says it has to be the ECU.
Has anyone else ever seen this?
racer-x6 is offline
Old 06-26-2007 | 11:31 AM
racer-x6's Avatar
also it does not have the shift switch and the DDT shows it to be in gear at all times.
racer-x6 is offline
Old 06-26-2007 | 01:30 PM
crank shaft position sensor. Replace it
Vyper340 is offline
mg503
Baja
14
04-03-2013 04:50 PM
TeamPSI
23
12-10-2007 05:23 PM
apexer
11
07-20-2007 07:24 PM
westcoaster
3
08-08-2005 11:24 AM
NVRENOUGH
3
02-18-2002 12:25 PM
