Check these Mufflers out!!!
Old 06-28-2007 | 02:21 PM
Default Check these Mufflers out!!!
Zoomers Cyclones Marine Muffler Long Barrel - 4" Clamp On - $719.00
Detailed Description
Clamp-On tips include set screws
12.5” Overall Length
6” Body Diameter
4” Inlet
4” Outlet
7.5 Weight
Zoomers Cyclone muffler design allows for an efficient flow-through muffler. As the turbulent exhaust gases and water enters the chamber's larger diameter, it is contoured and spun by it's patent protected stationary vaines. The result is a drop in pressure, which scavenges the water and gas. This scavenging effect allows your engine to breathe better resulting in increased performance.
Zoomers Cyclones Tests:
26' Commander with a 496 HO (425HP) - Stock 94.0 dB
26' Commander with a 496 HO (425HP) - Zoomers 84.0 dB
29' Shockwave GT Performance with a 3300 Whipple Supercharger (850HP) - Stock 102.0 dB
29' Shockwave GT Performance with a 3300 Whipple Supercharger (850HP) - Zoomers 87.8 dB
Test conducted by HotBoat Magazine (March 2005 Issue) showed little or no loss of RPM when compared to stock set-up.
tpmarine.com is offline
Old 06-28-2007 | 02:52 PM
Zoomers Cyclones Marine Muffler Short Barrel - 4" Clamp On - $619.00
10” Overall Length
6” Body Diameter
4” Inlet
4” Outlet
7.5 Weight
Old 06-28-2007 | 02:56 PM
Zoomers Cyclones Marine Muffler Long Barrel - 4" Thru Transom - $759.00
This is the thru-transom version and takes the place of your existing exhaust tips.
6” Body Diameter
4” Inlet
4” Outlet
7.5 Weight
Old 06-28-2007 | 03:00 PM
Zoomers Cyclones Marine Muffler Short Barrel - 4" Thru Transom - $669.00
This is a shorter version of the long barrel but is also a thru-transom set-up and takes the place of your existing tips.
Thru Transom includes hardware
10” Overall Length
6” Body Diameter
4” Inlet
4” Outlet
7.5 Weight
Old 06-28-2007 | 03:10 PM
Zoomers also offers these mufflers in a 4.5" & 5" clamp-on version.
Zoomers Cyclones Marine Muffler Long Barrel - 4.5" Clamp On - $719.00
Zoomers Cyclones Marine Muffler Long Barrel - 5" Clamp On - $719.00
Old 06-29-2007 | 03:58 PM
Zoomers Marine Mufflers utilize a patent protected technology to reduce dB without robbing horsepower...
Old 07-20-2007 | 10:11 AM
Here is a set of the long barrel 4" clamp on mufflers installed...
The clamp on version use a set screw to prevent the mufflers from working them selves loose and falling to the bottom of the lake...
Old 08-14-2007 | 09:16 PM
DB's Avatar
DB
Default 500 efi db levels
Zoomers look great has anyone done db level tests on Mercury 500 efi and if so what were the db levels ?
I would gladly spend $1400 to pass noise test but wouldn't be real happy if they can't pass.
DB is offline
Old 08-15-2007 | 08:52 AM
DB, yes they have...hotboat tested them and on a 496 mag & 525 engine package.
496 Mag 82.9 dB
525 87.7 dB
Let me know if you have any other questions.
Thanks,
Don B.
Old 08-16-2007 | 10:30 PM
Sonny Spectre 30's Avatar
How safe are they to use with out the set screw. Not crazy about the idea of putting a hole in the exhaust pipes, because it will look bad when not running the mufflers?
Sonny Spectre 30 is offline
