Resonable price for trimming down the Hook/Wedge
What is a reasonable price for trimming down the hook in an older Formula? Hook is 3/4" with a 3' straight edge - would like to get it ground down to 1/4" and gel coated, or is filling in an option?
Attaching picture of similar boat with standard Hook (Thanks mopower)
is the hook on both sides?
08 OPA High Points Champion
cool, that was gonna be my next question. if it can be done on the trailer and kept confined to that area it may not be to bad, maybe seven-eight hundred and that will depend on weather the hook can be removed by taking the material off at the rear most running surface. otherwise it will need to be filled ahead of that area and it will affect final price. in other words if this can be done removing fiberglass alone it shouldn't be to bad but if it will need filled/faired beyond that it could get pricey.
