Who Has Or Sell Sea Strainer Cap With Reg Hose Fitting? >
Old 07-01-2007 | 10:54 PM
jeff32's Avatar
Default Who Has Or Sell Sea Strainer Cap With Reg Hose Fitting?
Just want to simplify the task when I want to run engines on hoses... does it exist or I have to invent this by myself?
Tell me if you already have this!!!
Thanks.
jeff32 is offline
Old 07-02-2007 | 05:25 AM
scottc's Avatar
It's out there. Look in the back of some larger boat mags. They woek great.
scottc is offline
Old 07-02-2007 | 06:42 AM
GLH's Avatar
GLH
Call Fred at Trick Marine
GLH is offline
Old 07-02-2007 | 08:27 AM
B38
Yes, great idea, I have gill strainers with plastic lid 1/2" thick.
Why not thread for a garden hose barb connection for engine flush.
I could use that forsure times two.
B38 is offline
Old 06-12-2008 | 07:54 PM
jeff32's Avatar
bringing back this tread. still don't have a fresh water flush system for TRS, AND, Trick marine does not exist anymore, so... any suggestion where I can find those?
jeff32 is offline
Old 06-12-2008 | 10:03 PM
Pit's Avatar
Pit
M&M will sell you some stainers that has a port for a flush or you could pipe them in yourself.
Pit is offline
Old 06-12-2008 | 10:55 PM
Strip Poker 388's Avatar
Rob
I would think it would be hard to drill and tap it with out it cracking, I replaced mine from over tighten and cracked,
Strip Poker 388 is offline
Old 06-12-2008 | 11:01 PM
Rob
On my Hustler it has a plastic/PVC T fitting on the inlet hose close to the transom. goes to a valve to select from port and star. I can take a pick if ya need one, should be cheap, you could even leave off the valve and just cap the end and hook a water hose when ya want to flush.
post 104 http://www.offshoreonly.com/forums/s...t=92301&page=3
Old 06-12-2008 | 11:53 PM
littledcsrodshop's Avatar
Not to try & sidetrack the thread but what did you have to pay for the new lid ? & what brand strainer was it ? I have a M.M. on the way that will be needing a new lid... I was told that it is the same as the Gil but not sure... I have emailed a couple people trying to get a price including M.M. & no luck yet getting a response. Thanks , Scott
littledcsrodshop is offline
Old 06-13-2008 | 12:12 AM
Rob
I want to say 40-50 on the gil, my CP perf for the blower has allready cracked, I need to get a new one for it. I dont think the mm is the same as gil,its closer to the CP/hardin
