350 mpi
Old 07-06-2007 | 11:10 PM
Default 350 mpi
I have a 350 mpi. It cranks but does not turn over. There is gas in the MPI rails and good spark, but only goes to start when gas is poured in the top of the plenum (throttle housing). Any ideas?
Brian
brian valery is offline
Old 07-07-2007 | 03:38 AM
your injectors arent pulsing in time with the timing of the engine----strange you have spark though as in some or most automotive applications the spark and injection are run by the same sensor----usually a crank sensor or cam sensor is the culprit when these systems fail----also check the fuse box if applicable to see if an injection fuse may have blown---if you replace it and it blows again something is overloading that system voltage wise and you should have it checked. good luck with it.
checkmate DOH!! is offline
Old 07-08-2007 | 10:43 AM
Default 350 mpi same problem
I am having the same problem. After running the boat friday the port motor stalled and wont restart. It will run on starting fluid. I swapped the computer with my other motor and still no luck. Where are the sensors located that you think might be bad ?
area51scarab is offline
Old 07-08-2007 | 10:58 AM
We are trying the MAP sensor today. It is in front of the throttle body screwed to the manifold. It have a plug connector. I will let you know if that is it. Let me know if you find anything on yours. THanks
Old 07-08-2007 | 11:38 AM
Dave_N's Avatar
I don't think a MAP sensor is your problem. Have you checked fuel pressure?
Dave
Dave_N is offline
Old 07-08-2007 | 08:04 PM
Your right - it wasn't the MAP sensor. We replaced all plugs and wires and it started up. Tomorrow I am going to check fuel pressure and clean all injectors. I will keep you updated. Thanks
need more HP
3
06-04-2007 01:41 PM
Jeff Pierpont
6
06-02-2004 09:38 PM
justinVIP
17
11-18-2003 10:43 AM
BAD HTM SR 24
04-13-2003 07:58 AM
Scarab P-29
8
09-03-2002 01:13 AM
