Seastrainer needed to stop a slug of sand... >
Old 07-10-2007 | 07:56 AM
zimm17's Avatar
Default Seastrainer needed to stop a slug of sand...
I found out the hard way that a IMCO lower will not tolerate brushing over a sandbar. It picked up so much sand the pump pushed sand into my intercooler, heat exhanger, then plugged the 1 1/4" line on the output side of the pump. It took me hours to get the lines off and blow them all out- then I had 2" of sand in my bilge to get out. What a mess. I don't want to do that again, and there no avoiding shallow sandy areas around VA beach.
I know sea strainers don't block sand, but if they will catch a big slug of it so it won't clog my lines, that's better than nothing.
I don't need a $600 fancy model either- no beauty contest going on in my bildge. I found some cheaper models, but don't know how well they work.
Groco makes a brass and glass one for $140. Don't know how it comes apart though.
I also found this Sherwood unit for $42- and it has a removeable lower bowl which might work best for getting sand out of the unit. Looks small in the picture though.
The rexmar unit has a fitting for my pressure blowoff feeding the intercooler- avoids the "t" in my line. I just don't know if having the input and output fittings in the bottom of the strainer is a good idea to try and stop sand. It's $399.
What do you all think?
I'd like to avoid a through transom pickup if at all possible. Less holes in my boat.
Attached Thumbnails Seastrainer needed to stop a slug of sand...-sherwood.jpg   Seastrainer needed to stop a slug of sand...-rex.jpg
zimm17 is offline
Old 07-10-2007 | 09:17 AM
zimm17's Avatar
I did some more research and it looks the new ARG groco is the unit to get. Last forever and easy to service. The next question is to go with 1" npt or 1 1/4npt for the 1 1/4" hose barbs?
Attached Thumbnails Seastrainer needed to stop a slug of sand...-groco-arg.jpg
zimm17 is offline
Old 07-10-2007 | 10:39 AM
I use the Perko system similar to the Graco. The taller the better. Keeps the sand further away from the pump side line.
They are a must for a deep water pick up.
Jim
michigan troll is offline
Old 07-10-2007 | 11:23 AM
zimm17's Avatar
Thanks. I ordered the 1 1 /4" greko model. $165!!!
zimm17 is offline
Old 07-10-2007 | 10:58 PM
zimm - I need one also. Where did you order yours from ?
Thanks !!
Kidnova is offline
Old 07-11-2007 | 05:22 AM
zimm17's Avatar
www.go2marine.com
it shipped the day I ordered it.
zimm17 is offline
Old 07-13-2007 | 08:03 PM
www.go2marine.com
Thank you for the link !!
Kidnova is offline
randy carlson
3
02-26-2008 11:26 AM
mxzx
9
08-23-2004 04:00 PM
toptrim
10
07-16-2002 11:06 PM
Dredgeking
10
05-06-2002 07:29 PM
