Fenders for Dock Posts
Check out Fender Suspenders. Do the Math aka Fender Suspenders is an advertiser on this site and I have some both for the boat and dock and they work out great.
If you are looking for something more permanant then just go to you local dock supply house and get the long rubber that screws lengthwise into the piling...comes in non-marking black and white.
Chris~
Aside of Mike being 100% correct - lol!, (but you knew that already)
If you know an active fire fighter, have them get you a length / roll or two of 4" or 5" hose - they need to "retire" them after so long, and it is perfect for what you are looking for. They don't sell it or give it away, but if you know someone in the dept., they can / will usually get it for you - free
. I have all my dock posts lined with it where boats come into contact with them, it is a soft nylon braid on the outside and rubber on the inside. Basically, cut it to length, lay it flat, (so it is double-thick), tack it to the posts with aluminum roofing nails (well above and below the rub rail area) and you're good-to-go. We have had ours on there for years and it still works great, feel free to swing by anytime and take a look - always have beer water and soda cold in the fridge!
Mark
. I have all my dock posts lined with it where boats come into contact with them, it is a soft nylon braid on the outside and rubber on the inside. Basically, cut it to length, lay it flat, (so it is double-thick), tack it to the posts with aluminum roofing nails (well above and below the rub rail area) and you're good-to-go. We have had ours on there for years and it still works great, feel free to swing by anytime and take a look - always have beer water and soda cold in the fridge! Mark
Go to your local fire dept and ask if they have any old fire hose (they have to replace so often, if not put your name on a list). Cut strips and mount on your pilings. Works great, is cheap, and has been done for years by big-bodied water area home owners. Otherwise, if you go to like West Marine, or any other online dock store you will pay about $40-50 for a single strip of 6 feet.
Fire hose sounds like the cheapest way out. You can buy it at most hose shops. Look under hose in the yellow pages.
The real name is 44-250 mill discharge hose. The 3" hose(4-3/4" flat) is $2.09 per foot. The 4" or 5" shouldn't be too much more.
Found a 4 3/4" x 100' roll for $100 new. Now I just need to figure out how I want to attach them. My only concern with the roofing nails are the variety of boats that will beon the dock.
There is a company that makes floating piling covers, made of a material like polyethylene. Saw it at a boat show, pretty slick idea. Always stays at the same height compared to the boat. Can attach rings or cleats to them too.
Not too cheap though.
