Flushing Motors......how long?? >
Old 07-17-2007 | 03:40 PM
Default Flushing Motors......how long??
Just curious how long is enough when flushing your motors with fresh water..............
Here's Johnny is offline
Old 07-17-2007 | 04:10 PM
Fountain38SC's Avatar
I go 5 mins after it runs fresh. Taste it- not scientific but no probs so far and use salt away!
Fountain38SC is offline
Old 07-17-2007 | 04:17 PM
Dude! Sweet!'s Avatar
HA! My friends all cringe when I taste the exhaust on my boat. I run two cups of salt away through it and then let it run for another 5 minutes ish.
Dude! Sweet! is offline
Old 07-17-2007 | 04:36 PM
CROWN MAN's Avatar
Only because I love my neighbors so much,, 15min (or 3 beers) on fresh water then 1 cup salt away...after every use
I also bring the motor up to temp on the hose before i hit the ramp. Sunday mornings - they love that !!!
CROWN MAN is offline
Old 07-17-2007 | 05:00 PM
so most of you feel that 5 minutes per side is not enough..... I usually avg. between 5 and 10 minutes....... never actually tasted the water from the exhaust but will give it a shot (no pun intended) next weekend......................................Johnn y
Old 07-17-2007 | 05:45 PM
FeverMike's Avatar
5 min per motor mybe 10 max. Never had a salt problem. I use salt-a-way once a month or so.
FeverMike is offline
Old 07-17-2007 | 08:32 PM
Stormrider's Avatar
JC Performance Engines
Johnny, 5mins and take a taste.
Stormrider is offline
Old 07-17-2007 | 08:34 PM
what's up Rob.........tried to call you today and then I got real busy.........i will be watching the weather for next Monday if you want to hit Bracco's...........I will call you during the day tomorrow.....................................Johnn y
Old 07-17-2007 | 09:16 PM
i run the for bout 5 or so mins never used salt away though
fountainguy214 is offline
Old 07-17-2007 | 09:21 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
If your motor has a thermostat, you MUST run it long enough to bring the motor up to temp to fully open the thermostat, and flush out the salt water that is in the entire system.
I do the taste test as well.
Sydwayz is offline
