I just bought a new 38 Lightning...... >
Old 07-17-2007 | 07:26 PM
Question I just bought a new 38 Lightning......
I am the owner of a 2005 new 38 Lightning with 525's that I am keeping in Longport NJ. This is my first "go boat" and I want to make sure I don't screw anything up. I am the first owner of the boat and there is about an hour on each engine. What do I need to know that my dealer might not have told me?
If any of the following doesn't make sense I ask that someone please tell me. The dealer recommends the following:
- Check the engine oil each time I use the boat...the dealer recommends warming the engines shutting them off and then checking the oil
- the dealer recommends checking the drive oil and tab fluid each use. How much of these fluids does the boat "consume" over what time period?
the dealer recommends changing the engine oil at every 25 -40 engine hour intervals. How hard is this to do yourself?
Does it make sense to turn the batteries to "off" after each use?
How often should the boat be waxed (I use the boat in salt water)?
Other then that if there is any other Fountain owners in the Atlantic City area let me know.
TJ
TJ Bart is offline
Old 07-17-2007 | 07:32 PM
DiamondPerformance's Avatar
Offshoreonly Advertiser
Great boat, have fun with it!
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 07-17-2007 | 07:51 PM
ReggieRaft's Avatar
Yes you should turn off the batteries evertime you are finished with the boat for the day it helps stop electrolisis.You need a vaccum pump to change the oil . Get the electric one at west marine. Join our boat club, NJPPC.com We have a few poker runs and party in AC all the time.
ReggieRaft is offline
Old 07-17-2007 | 08:03 PM
Congrats on the new purchase. Your boat is gorgeous, I saw it up there when I was picking up mine. I bought a new 05 35' Lightning from Coty Marine the last week of June. Did Richie and Joe take good care of you?
Check your fluids before each use and definitely cut off your batteries after each use.
I prefer to change the fluids at 20 hours just because it gives me a more peace of mind.
Viper TT is offline
Old 07-17-2007 | 08:13 PM
I was going back and forth between the 35 and 38 at the end of the last summer and I decided I wanted the 38 but Richie and I couldn't agree on a number last August. I went back last week and Richie and I figured it out.
How many hours did you put on your boat?
How much fluids has your boat been consuming?
How has the learning curve been? What are you finding most difficult?
I pick my boat up on Thursday and am concerned about docking it.....the biggest boat I have owned before has been a 20ft Bayliner
TJ Bart is offline
Old 07-17-2007 | 08:15 PM
Check your email. I've sent you my number. Give me a call.
Viper TT is offline
Old 07-17-2007 | 08:18 PM
THEJOKER's Avatar
Don't pack it with your friends / family and yell " watch this" and then try and turn it like you did your Bayliner.
THEJOKER is offline
Old 07-17-2007 | 08:19 PM
Downtown42's Avatar
NO_HIGH-SPEED TURNS_........
Wax every 60 days for salt use.
congrats have fun and be careful. You should have drain hoses for oil out your drain plugs. Still need a manual pump to screw on dipstick to get it all out.
Downtown42 is offline
Old 07-17-2007 | 08:43 PM
I've got 20 hours on the boat now, so I've been busy enjoying it! I have to say, it is an awesome boat and the family also loves going out on it.
I have not had any fluid consumption problems. I will be doing my first fluids change this week, so I'll let you know how it goes.
In all honesty, I've not had much trouble with learning the boat. Drive and Tab trimming you will get used to once you've been out a few times and experience it. Docking is not bad at all once I learned to relax and move slowly. I use the drives more than the steering when docking, which works well for me as long as the steering is centered.
What I find the most difficult is to tie the boat off at a dock! I've provided some entertainment to the surrounding boaters at the docks! I've had comments from more than one stating they thought I really knew what I was doing by the way I pulled the boat into the slip, until I starting to tie the boat down where it went downhill quick!
Viper TT is offline
Old 07-17-2007 | 10:14 PM
FeverMike's Avatar
Most important thing with a slipery step bottom boat is...
do not trim in past level and turn it hard. Keep it trimmed out for turns at speed and with the tabs up.
FeverMike is offline
